TX2 suspend fail.
Jun 10 23:17:42 tegra-ubuntu kernel: [ 5016.933798] Wake[32:0] status=0x0
Jun 10 23:17:42 tegra-ubuntu kernel: [ 5016.933798] Wake[64:32] status=0x0
Jun 10 23:17:42 tegra-ubuntu kernel: [ 5016.933798] Wake[96:64] status=0x0
cat /sys/kernel/debug/suspend_stats
success: 5
fail: 6
failed_freeze: 0
failed_prepare: 0
failed_suspend: 0
failed_suspend_late: 0
failed_suspend_noirq: 0
failed_resume: 0
failed_resume_early: 0
failed_resume_noirq: 0
failures:
last_failed_dev:
last_failed_errno: -95
-95
last_failed_step:
When suspend fail, the fail counts up.
Could you give reproduce information?
Any suspicious kernel message?
Did you connect any device?
How did you put your the device to suspend.
Could you try “sudo systemctl suspend” command.
I used “sudo systemctl suspend” like my description before.
Reproduce information
suspend using cmd : sudo systemctl suspend
wake-up using gpio ctrl : power button gpio signal 2sec
sometimes suspend fail occurs before wake-up using gpio ctrl
Bibek
July 3, 2020, 6:56am
11
Hence we are closing this topic. If need further support, please open a new one. Thanks
Can you remove the IOs connected and try?
Also can you share which release branch you are using.
Please share the complete boot log
