Suspend issue on Orin NX 16GB
Hi
In BSP Ver36.4.3, When I enter the Suspend command, Boot Mode is not set to SC7, but to Cold Boot.
The log of the event is attached.
jetson_suspend.txt (77.6 KB)
Is there a solution for this?
Thanks,
Is this a custom board?
Thank you for reply.
It’s developer kit(SOM and carrier board).
We don’t hit this issue. Does it always happen or an intermittent issue?
Hi
It happens every time.
Could you take a photo of both sides of your board?
Also, what are the peripherals connected on the board?
Peripheral equipment is display only.
Please remove the display and try to do the suspend again.
