Gentoo:
x11-drivers/nvidia-drivers-515.65.01
sys-kernel/gentoo-sources-5.15.59
After suspend to ram - resume several grey rectangles appear on screen.
on x11-drivers/nvidia-drivers-470.129.06: no problem.
Gentoo:
Did you enable video memory allocation preservation?
https://download.nvidia.com/XFree86/Linux-x86_64/495.44/README/powermanagement.html
memory allocation preservation were not enabled.
changed /etc/modprobe/nvidia.conf to
options nvidia
NVreg_PreserveVideoMemoryAllocations=1
NVreg_TemporaryFilePath=/home/nvidia
did a ‘systemctl enable nvidia-suspend.service nvidia-hibernate.service’
now system resumes automatically after suspend, screen is fine now.
Please run nvidia-bug-report.sh as root and attach the resulting nvidia-bug-report.log.gz file to your post.
nvidia-bug-report.log.gz (344.5 KB)
You’re running a wayland session so it runs into a bug on suspend
[ 119.698682] Freezing of tasks failed after 20.001 seconds (1 tasks refusing to freeze, wq_busy=0):
[ 119.699913] task:gnome-shell state:D stack: 0 pid: 2271 ppid: 2180 flags:0x00000006
[ 119.701530] Call Trace:
[ 119.702711] <TASK>
[ 119.703909] __schedule+0x2f3/0x9b0
[ 119.705101] schedule+0x44/0xb0
[ 119.706285] rwsem_down_read_slowpath+0x363/0x3b0
[ 119.707507] ? _nv002095kms+0x380/0x26c0 [nvidia_modeset]
[ 119.708762] nvkms_ioctl_from_kapi+0x27/0x90 [nvidia_modeset]
[ 119.709994] _nv002095kms+0x3d2/0x26c0 [nvidia_modeset]
[ 119.711240] ? nv_drm_gem_identify_object_ioctl+0x22b/0x240 [nvidia_drm]
[ 119.712453] ? drm_mode_rmfb+0x1b6/0x1f0
[ 119.713685] ? drm_mode_rmfb+0x1f0/0x1f0
[ 119.714882] ? drm_ioctl_kernel+0xaf/0x100
[ 119.716089] ? drm_ioctl+0x224/0x3e0
[ 119.717720] ? drm_mode_rmfb+0x1f0/0x1f0
[ 119.718934] ? __x64_sys_ioctl+0x8a/0xc0
[ 119.720166] ? do_syscall_64+0x3b/0xc0
[ 119.721380] ? entry_SYSCALL_64_after_hwframe+0x61/0xcb
[ 119.722573] </TASK>
installed https://us.download.nvidia.com/XFree86/Linux-x86_64/515.43.04/NVIDIA-Linux-x86_64-515.43.04.run
ok with this version …
but x11-drivers/nvidia-drivers-515.65.01 is more recent. could it be that there is regression?
Yes, an additional regression regarding suspend/resume was also reported for 515.65., depending on hardware used.
OK thanks for your prompt support.
Will wait for the fix of this problem.
I am willing to test on my hardware if you want.
