I got DeepStream 6.3 source code from docker nvcr.io/nvidia/deepstream:6.3-samples.
And I found gstnvinfer.cpp use batch.release() to pass GstNvInferBatch* to convert_batch_and_push_to_input_thread ().
But convert_batch_and_push_to_input_thread() does not delete “batch” before return FALSE.
Will it cause memory leak?
• DeepStream Version
• TensorRT Version
Thanks for your response.
The source code is from /opt/nvidia/deepstream/deepstream-6.3 in docker nvcr.io/nvidia/deepstream:6.3-samples.
I think the “code logic” may cause memory leak.
And it does not related to any hardware and other software version.
Caller is expected to delete object by itself after call std::unique_ptr<T,Deleter>::release.
I am okay to close this post if it is not an issue. Thanks :)
