SVM on cuda
Hello, how can give me an example of SVM code using CUDA and thank you all in advance.
As long as open sourced material is okay with you, LIBSVM and cuSVM are both options depending on your needs.
Thank you for your replay, is there any code source of SVM using this two libraries.
I’m sure if you googled it like i did for my original post you could find some. Or maybe looked in the github repositories they might have examples.
