After running “docker/run.sh” using jetson-inference, I am using “video-viewer” to output 4 RTSP streams.
Q1: The video can be output, but the SWAP usage gradually increases over time. is there some kind of memory leak in the RAM?
Also, when I stop “video-viewer” the SWAP usage decreases, but is still more than when “video-viewer” was started.
Q2: I would like to use valgrind’s Memcheck tool for jetson-inference. I would like to add the “-g -O0 option” at compile time.
Thank you very much for your help.
Our running environment is as follows.
-jetpack: 4.6
Docker version Docker version 20.10.7, build 20.10.7-0ubuntu5~18.04.3
Translated with DeepL Translate: The world's most accurate translator (free version)
Hi @nakayonum, I would recommend Building the Project from Source (outside of container) and adding those build flags to the CMakeLists.txt
Hi @dusty_nv
Thanks for your message.
its okay.
Do you have any idea what the other question is?
When I ran video-view I got the following
$ video-viewer --input-codec=h264 rtsp:XXXXX
rtspsrc location=XXXXX latency=2000 ! queue ! rtph264depay ! h264parse ! omxh264dec ! videoconvert ! appsink name=mysink
I saw omxh264dec WORKS nvv4l2decoder DOES NOT WORK.
Should I stop using omxh264dec and use nvv4l2decoder?
If so, what happens to the following command?
thank you
omxh264dec has been deprecated, so you should use nvv4l2decoder if possible. omxh264dec is still available on JetPack 4.x however. It has been removed in JetPack 5.x
Hi @dusty_nv
I see that omxh264dec was removed in JetPack 5.x.
Thanks for the info!
