swap pointers in device memory
In CUDA C, we can easily swap pointers to two different memory region, e.g. in finite-difference computation
begin loop
   // this kernel update output based on input
   mykernek<<< .... >>>( float* output, float* input)
   float* tmp =  output;
   output = input;
   input = tmp;
end loop
Is there something similar that we can do with CUDA Fortran, or Fortran language.
What i can think of is to unroll the loop
begin loop
! unroll 1
   ! this kernel update output based on input
   mykernek<<< .... >>>( output,  input)
  ! do other stuff
! unroll 2
   mykernek<<< .... >>>( input,  output)
  ! do other stuff
end loop
Is there a better way?
Thanks,
Tuan
We’ll there isn’t an easy way to swap pointers. I guess you could create ISO C c_ptr types but it seems to be an “un-Fortran” way to do it.
Your solution should work, but you could instead of unrolling, use an if statement to toggle which way to call the kernel based on the loop index. If odd call “output, input”, if even call “input, output”.
  • Mat
Will C_PTR work for pointer to device global memory when I try to use in Fortran?
Thanks Mat.
Tuan
