Hi!
I’m already running an embedded application on a NVIDIA TX1 with an Orbitty carrier board. I would now like to change the module to a TX2. As far as I can see, it should possible to swap the TX1 module for a TX2. Is it that simple?
Will the two modules also run the same version of Jetpack?
Best regards,
Sondre
