Hey guys, I’m having some issues successfully swapping pointers within a kernel.
I allocated two char arrays (for input and output) on the device using cudaMemAlloc() and passing the two arrays to a kernel. I plan on doing a time-stepping calculation, so using the input array to set values in the output. After the iteration, I want to swap the in and out array [so the output of the first call becomes the input of the second]. I have something, but it’s not working [of course]:
// main:
check_error(cudaMalloc((void **) & g_in, size*size*sizeof(char)));
check_error(cudaMalloc((void **) & g_out, size*size*sizeof(char)));
kernel <<< gridDims, threadDims >>> (g_in,g_out,size);
__device__ void swap(char **x, char **y) {
char *t = *x;
*x = *y;
*y = t;
__global__ kernel(char *in, char *out,int size)
int i = (blockDim.x * blockIdx.x) + threadIdx.x, j = (blockDim.y * blockIdx.y) + threadIdx.y;
if (i < 0 || i >= size || j < 0 || j >= size) return;
int index = i*size+j, g;
for (g = 0; g < 10; g++)
out[index] = g;
swap(&in,&out);
Any ideas? Thanks in advance.
