I am a deep learning engineer and I use keras + tensorflow + CUDA to train and test models. I have a testing interface set up which tests multiple models at once (in a loop). When running this program on CUDA8 I had no issues. After making the switch to CUDA9, I can no longer test more than two models at a time. If I try to test more than two models, I get a “segmentation fault (core dumped)” error and the program is forced to quit.
Does anyone know the cause of this issue?
M
