Hi NVIDIA Team,
We are currently working with Jetpack 6.2 on a Jetson Orin NX 16GB module, and we have a requirement to switch between “Super mode” and “Slandered mode” dynamically without re-flashing the device using required configuration as an argument.
To switch from “Super mode” to “Standard mode”, we followed below steps:
- Generate the Bootloader Capsule:
sudo ./l4t_generate_soc_bup.sh -b jetson-orin-nano-devkit -e t23x_3767_bl_spec t23x
./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t23x/bl_only_payload -o ./TEGRA_BL.Cap t234
Replace jetson-orin-nano-devkit-super with jetson-orin-nano-devkit- in /etc/nv_boot_control.conf
Use the Helper Script to Trigger the bootloader Capsule Update
nv_bootloader_capsule_updater.sh -q ./TEGRA_BL.Cap
- Add below in /boot/extlinux/extlinux.conf
FDT /boot/dtb/kernel_tegra234-p3768-0000+p3767-0000-nv.dtd
Copy kernel_tegra234-p3768-0000+p3767-0000-nv.dtb to /boot/dtb
Replace /etc/nvpmodel.conf with /etc/nvpmodel/nvpmodel_p3701_0000.conf
reboot board.
Validated with:
sudo nvpmodel -q
This showed expected Normal mode power profiles.
Questions
Are these steps correct for switching from Super mode to Normal mode?
Is there any additional steps or recommended change I may have missed?
Can we follow the same process in reverse (i.e., modifying config, generating capsule for “Super mode”, updating DTB and nvpmodel) to switch back to “Super mode” without requiring a reflash?
Thank you,
Brijesh
