Using the latest Jetpack 3.3, we see an odd artifact. When switching the V4L2Buffer buf.m.userptr after the frame has been dequeued, the screen flickers when the buffer is requeued to the driver.
I’d like to keep all incoming images from the V4L2 interface for a period of time (caching them to collect a bayer image set), ideally, without copying them.
One approach that seams plausible is simply re-assigning the V4L2 buffer buf.m.userptr after a V4L2 buffer has been dequeued, before re-queueing it as mentioned.
If we use the /tegra_multimedia_api/samples/v4l2cuda/capture.cpp example with the stock camera:
static const char * dev_name = "/dev/video0";
static io_method io = IO_METHOD_USERPTR;
static int fd = -1;
struct buffer * buffers = NULL;
static unsigned int n_buffers = 0;
static unsigned int width = 2592;
static unsigned int height = 1944;
static unsigned int count = 10;
static unsigned char * cuda_out_buffer = NULL;
static bool cuda_zero_copy = true;
static const char * file_name = "out.ppm";
static unsigned int pixel_format = V4L2_PIX_FMT_SBGGR10;
static unsigned int field = V4L2_FIELD_NONE;
and modify this function to demonstrate the behaviour:
static int
read_frame (void)
struct v4l2_buffer buf;
unsigned int i;
switch (io) {
case IO_METHOD_READ:
break;
case IO_METHOD_MMAP:
break;
case IO_METHOD_USERPTR:
CLEAR (buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_USERPTR;
if (-1 == xioctl (fd, VIDIOC_DQBUF, &buf)) {
switch (errno) {
case EAGAIN:
return 0;
case EIO:
/* Could ignore EIO, see spec. */
/* fall through */
default:
errno_exit ("VIDIOC_DQBUF");
for (i = 0; i < n_buffers; ++i)
if (buf.m.userptr == (unsigned long) buffers[i].start
&& buf.length == buffers[i].length)
break;
assert (i < n_buffers);
/* START TEST CODE */
//process_image ((void *) buf.m.userptr);
// intentionally not freed for test
cudaError err = cudaMallocManaged (&buffers[i].start, buffers[i].length, cudaMemAttachGlobal);
if( err != cudaSuccess) {
printf("cudaMallocManaged failed!\n");
err = cudaDeviceSynchronize();
printf("cudaDeviceSynchronize failed!\n");
buf.m.userptr = (unsigned long) buffers[i].start;
printf("new pointer for buffer %d = %p\n", i, buffers[i].start);
/* END OF TEST CODE */
if (-1 == xioctl (fd, VIDIOC_QBUF, &buf))
errno_exit ("VIDIOC_QBUF");
break;
return 1;
Interestingly, if we wait 1 frame before re-queueing, i.e.
usleep(33000);
we don’t see this issue. It seems as though there is some kind of race condition or DMA activity still going on underneath after the frame is de-queued.
If we increase n_buffers to 10, the behavior is the same (I was curious).
The concern is whether we have a possible race condition accessing the data if we have a fast kernel that operates on the fresly de-queued image? If the buf.m.userptr is de-queued and in user-space, to me it seems like the buffer should be complete, and ready to access at will.
Here is a video (capturing 100 frames), sorry about the poor camera:
https://drive.google.com/open?id=1mfPsA3xZiA4DRxpoW5_coOy9KfVl-jM_
If we take this one step further and cache the image data for each buffer (keeping the CUDA pointers and assigning new ones before re-queueing the buffer), de-bayering them and writing them back to disk, we see torn frames or black rows in some of the images. Some image data is incomplete, but V4L2_BUF_FLAG_ERROR is not set. Some images are fine. If we add the aforementioned ~33 ms delay the image data is correct.
Any thoughts on why this happens?
Full code for stock camera to copy and paste for testing this:
* Copyright (c) 2015, NVIDIA CORPORATION. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
* copy of this software and associated documentation files (the "Software"),
* to deal in the Software without restriction, including without limitation
* the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the
* Software is furnished to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in
* all copies or substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
* FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
* THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
* LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
* V4L2 video capture example
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <assert.h>
#include <getopt.h> /* getopt_long() */
#include <fcntl.h> /* low-level i/o */
#include <unistd.h>
#include <errno.h>
#include <malloc.h>
#include <sys/stat.h>
#include <sys/types.h>
#include <sys/time.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <asm/types.h> /* for videodev2.h */
#include <linux/videodev2.h>
#include <cuda_runtime.h>
#include "yuv2rgb.cuh"
#define CLEAR(x) memset (&(x), 0, sizeof (x))
#define ARRAY_SIZE(a) (sizeof(a)/sizeof((a)[0]))
typedef enum {
IO_METHOD_READ,
IO_METHOD_MMAP,
IO_METHOD_USERPTR,
} io_method;
struct buffer {
void * start;
size_t length;
static int fd = -1;
static void
errno_exit (const char * s)
fprintf (stderr, "%s error %d, %s\n",
s, errno, strerror (errno));
exit (EXIT_FAILURE);
static int
xioctl (int fd,
int request,
void * arg)
int r;
do r = ioctl (fd, request, arg);
while (-1 == r && EINTR == errno);
return r;
static void
process_image (void * p)
printf ("CUDA format conversion on frame %p\n", p);
gpuConvertYUYVtoRGB ((unsigned char *) p, cuda_out_buffer, width, height);
/* Save image. */
if (count == 0) {
FILE *fp = fopen (file_name, "wb");
fprintf (fp, "P6\n%u %u\n255\n", width, height);
fwrite (cuda_out_buffer, 1, width * height * 3, fp);
fclose (fp);
static int
read_frame (void)
unsigned int i;
switch (io) {
if (-1 == read (fd, buffers[0].start, buffers[0].length)) {
switch (errno) {
case EAGAIN:
return 0;
case EIO:
/* fall through */
default:
errno_exit ("read");
process_image (buffers[0].start);
break;
CLEAR (buf);
buf.memory = V4L2_MEMORY_MMAP;
switch (errno) {
case EAGAIN:
return 0;
case EIO:
/* fall through */
default:
assert (buf.index < n_buffers);
process_image (buffers[buf.index].start);
break;
CLEAR (buf);
switch (errno) {
case EAGAIN:
return 0;
case EIO:
/* fall through */
default:
break;
break;
return 1;
static void
mainloop (void)
while (count-- > 0) {
for (;;) {
fd_set fds;
struct timeval tv;
int r;
FD_ZERO (&fds);
FD_SET (fd, &fds);
/* Timeout. */
tv.tv_sec = 2;
tv.tv_usec = 0;
r = select (fd + 1, &fds, NULL, NULL, &tv);
if (-1 == r) {
if (EINTR == errno)
continue;
errno_exit ("select");
if (0 == r) {
fprintf (stderr, "select timeout\n");
if (read_frame ())
break;
/* EAGAIN - continue select loop. */
static void
stop_capturing (void)
enum v4l2_buf_type type;
switch (io) {
/* Nothing to do. */
break;
if (-1 == xioctl (fd, VIDIOC_STREAMOFF, &type))
errno_exit ("VIDIOC_STREAMOFF");
break;
static void
start_capturing (void)
unsigned int i;
switch (io) {
break;
for (i = 0; i < n_buffers; ++i) {
CLEAR (buf);
buf.index = i;
if (-1 == xioctl (fd, VIDIOC_STREAMON, &type))
errno_exit ("VIDIOC_STREAMON");
break;
CLEAR (buf);
buf.index = i;
buf.length = buffers[i].length;
break;
static void
uninit_device (void)
unsigned int i;
switch (io) {
free (buffers[0].start);
break;
if (-1 == munmap (buffers[i].start, buffers[i].length))
errno_exit ("munmap");
break;
if (cuda_zero_copy) {
cudaFree (buffers[i].start);
} else {
free (buffers[i].start);
break;
free (buffers);
cudaFree (cuda_out_buffer);
static void
init_read (unsigned int buffer_size)
buffers = (struct buffer *) calloc (1, sizeof (*buffers));
if (!buffers) {
fprintf (stderr, "Out of memory\n");
buffers[0].length = buffer_size;
buffers[0].start = malloc (buffer_size);
if (!buffers[0].start) {
static void
init_mmap (void)
struct v4l2_requestbuffers req;
CLEAR (req);
req.count = 4;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
if (-1 == xioctl (fd, VIDIOC_REQBUFS, &req)) {
if (EINVAL == errno) {
fprintf (stderr, "%s does not support "
"memory mapping\n", dev_name);
} else {
errno_exit ("VIDIOC_REQBUFS");
if (req.count < 2) {
fprintf (stderr, "Insufficient buffer memory on %s\n",
dev_name);
buffers = (struct buffer *) calloc (req.count, sizeof (*buffers));
if (!buffers) {
for (n_buffers = 0; n_buffers < req.count; ++n_buffers) {
CLEAR (buf);
buf.index = n_buffers;
if (-1 == xioctl (fd, VIDIOC_QUERYBUF, &buf))
errno_exit ("VIDIOC_QUERYBUF");
buffers[n_buffers].length = buf.length;
buffers[n_buffers].start =
mmap (NULL /* start anywhere */,
buf.length,
PROT_READ | PROT_WRITE /* required */,
MAP_SHARED /* recommended */,
fd, buf.m.offset);
if (MAP_FAILED == buffers[n_buffers].start)
errno_exit ("mmap");
static void
init_userp (unsigned int buffer_size)
unsigned int page_size;
page_size = getpagesize ();
buffer_size = (buffer_size + page_size - 1) & ~(page_size - 1);
CLEAR (req);
req.count = 4;
req.memory = V4L2_MEMORY_USERPTR;
"user pointer i/o\n", dev_name);
} else {
buffers = (struct buffer *) calloc (4, sizeof (*buffers));
if (!buffers) {
for (n_buffers = 0; n_buffers < 4; ++n_buffers) {
buffers[n_buffers].length = buffer_size;
cudaMallocManaged (&buffers[n_buffers].start, buffer_size, cudaMemAttachGlobal);
} else {
buffers[n_buffers].start = memalign (/* boundary */ page_size,
buffer_size);
if (!buffers[n_buffers].start) {
static void
init_device (void)
struct v4l2_capability cap;
struct v4l2_cropcap cropcap;
struct v4l2_crop crop;
struct v4l2_format fmt;
unsigned int min;
if (-1 == xioctl (fd, VIDIOC_QUERYCAP, &cap)) {
fprintf (stderr, "%s is no V4L2 device\n",
dev_name);
} else {
errno_exit ("VIDIOC_QUERYCAP");
if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE)) {
fprintf (stderr, "%s is no video capture device\n",
dev_name);
switch (io) {
if (!(cap.capabilities & V4L2_CAP_READWRITE)) {
fprintf (stderr, "%s does not support read i/o\n",
dev_name);
break;
if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
fprintf (stderr, "%s does not support streaming i/o\n",
dev_name);
break;
/* Select video input, video standard and tune here. */
CLEAR (cropcap);
cropcap.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
if (0 == xioctl (fd, VIDIOC_CROPCAP, &cropcap)) {
crop.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
crop.c = cropcap.defrect; /* reset to default */
if (-1 == xioctl (fd, VIDIOC_S_CROP, &crop)) {
switch (errno) {
case EINVAL:
/* Cropping not supported. */
break;
default:
/* Errors ignored. */
break;
} else {
CLEAR (fmt);
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = width;
fmt.fmt.pix.height = height;
fmt.fmt.pix.pixelformat = pixel_format;
fmt.fmt.pix.field = field;
if (-1 == xioctl (fd, VIDIOC_S_FMT, &fmt))
errno_exit ("VIDIOC_S_FMT");
/* Note VIDIOC_S_FMT may change width and height. */
/* Buggy driver paranoia. */
min = fmt.fmt.pix.width * 2;
if (fmt.fmt.pix.bytesperline < min)
fmt.fmt.pix.bytesperline = min;
min = fmt.fmt.pix.bytesperline * fmt.fmt.pix.height;
if (fmt.fmt.pix.sizeimage < min)
fmt.fmt.pix.sizeimage = min;
switch (io) {
init_read (fmt.fmt.pix.sizeimage);
break;
init_mmap ();
break;
init_userp (fmt.fmt.pix.sizeimage);
break;
static void
close_device (void)
if (-1 == close (fd))
errno_exit ("close");
fd = -1;
static void
open_device (void)
struct stat st;
if (-1 == stat (dev_name, &st)) {
fprintf (stderr, "Cannot identify '%s': %d, %s\n",
dev_name, errno, strerror (errno));
if (!S_ISCHR (st.st_mode)) {
fprintf (stderr, "%s is no device\n", dev_name);
fd = open (dev_name, O_RDWR /* required */ | O_NONBLOCK, 0);
if (-1 == fd) {
fprintf (stderr, "Cannot open '%s': %d, %s\n",
static void
init_cuda (void)
/* Check unified memory support. */
cudaDeviceProp devProp;
cudaGetDeviceProperties (&devProp, 0);
if (!devProp.managedMemory) {
printf ("CUDA device does not support managed memory.\n");
cuda_zero_copy = false;
/* Allocate output buffer. */
size_t size = width * height * 3;
cudaMallocManaged (&cuda_out_buffer, size, cudaMemAttachGlobal);
} else {
cuda_out_buffer = (unsigned char *) malloc (size);
cudaDeviceSynchronize ();
static void
usage (FILE * fp,
int argc,
char ** argv)
fprintf (fp,
"Usage: %s [options]\n\n"
"Options:\n"
"-c | --count N Frame count (default: %u)\n"
"-d | --device name Video device name (default: %s)\n"
"-f | --format Capture input pixel format (default: UYVY)\n"
"-h | --help Print this message\n"
"-m | --mmap Use memory mapped buffers\n"
"-o | --output Output file name (default: %s)\n"
"-s | --size WxH Frame size (default: %ux%u)\n"
"-u | --userp Use application allocated buffers\n"
"-z | --zcopy Use zero copy CUDA memory\n"
"Experimental options:\n"
"-r | --read Use read() calls\n"
"-F | --field Capture field (default: INTERLACED)\n"
argv[0], count, dev_name, file_name, width, height);
static const char short_options [] = "c:d:f:F:hmo:rs:uz";
static const struct option
long_options [] = {
{ "count", required_argument, NULL, 'c' },
{ "device", required_argument, NULL, 'd' },
{ "format", required_argument, NULL, 'f' },
{ "field", required_argument, NULL, 'F' },
{ "help", no_argument, NULL, 'h' },
{ "mmap", no_argument, NULL, 'm' },
{ "output", required_argument, NULL, 'o' },
{ "read", no_argument, NULL, 'r' },
{ "size", required_argument, NULL, 's' },
{ "userp", no_argument, NULL, 'u' },
{ "zcopy", no_argument, NULL, 'z' },
{ 0, 0, 0, 0 }
static struct {
const char *name;
unsigned int fourcc;
} pixel_formats[] = {
{ "RGB332", V4L2_PIX_FMT_RGB332 },
{ "RGB555", V4L2_PIX_FMT_RGB555 },
{ "RGB565", V4L2_PIX_FMT_RGB565 },
{ "RGB555X", V4L2_PIX_FMT_RGB555X },
{ "RGB565X", V4L2_PIX_FMT_RGB565X },
{ "BGR24", V4L2_PIX_FMT_BGR24 },
{ "RGB24", V4L2_PIX_FMT_RGB24 },
{ "BGR32", V4L2_PIX_FMT_BGR32 },
{ "RGB32", V4L2_PIX_FMT_RGB32 },
{ "Y8", V4L2_PIX_FMT_GREY },
{ "Y10", V4L2_PIX_FMT_Y10 },
{ "Y12", V4L2_PIX_FMT_Y12 },
{ "Y16", V4L2_PIX_FMT_Y16 },
{ "UYVY", V4L2_PIX_FMT_UYVY },
{ "VYUY", V4L2_PIX_FMT_VYUY },
{ "YUYV", V4L2_PIX_FMT_YUYV },
{ "YVYU", V4L2_PIX_FMT_YVYU },
{ "NV12", V4L2_PIX_FMT_NV12 },
{ "NV21", V4L2_PIX_FMT_NV21 },
{ "NV16", V4L2_PIX_FMT_NV16 },
{ "NV61", V4L2_PIX_FMT_NV61 },
{ "NV24", V4L2_PIX_FMT_NV24 },
{ "NV42", V4L2_PIX_FMT_NV42 },
{ "SBGGR8", V4L2_PIX_FMT_SBGGR8 },
{ "SGBRG8", V4L2_PIX_FMT_SGBRG8 },
{ "SGRBG8", V4L2_PIX_FMT_SGRBG8 },
{ "SRGGB8", V4L2_PIX_FMT_SRGGB8 },
{ "SBGGR10_DPCM8", V4L2_PIX_FMT_SBGGR10DPCM8 },
{ "SGBRG10_DPCM8", V4L2_PIX_FMT_SGBRG10DPCM8 },
{ "SGRBG10_DPCM8", V4L2_PIX_FMT_SGRBG10DPCM8 },
{ "SRGGB10_DPCM8", V4L2_PIX_FMT_SRGGB10DPCM8 },
{ "SBGGR10", V4L2_PIX_FMT_SBGGR10 },
{ "SGBRG10", V4L2_PIX_FMT_SGBRG10 },
{ "SGRBG10", V4L2_PIX_FMT_SGRBG10 },
{ "SRGGB10", V4L2_PIX_FMT_SRGGB10 },
{ "SBGGR12", V4L2_PIX_FMT_SBGGR12 },
{ "SGBRG12", V4L2_PIX_FMT_SGBRG12 },
{ "SGRBG12", V4L2_PIX_FMT_SGRBG12 },
{ "SRGGB12", V4L2_PIX_FMT_SRGGB12 },
{ "DV", V4L2_PIX_FMT_DV },
{ "MJPEG", V4L2_PIX_FMT_MJPEG },
{ "MPEG", V4L2_PIX_FMT_MPEG },
static unsigned int v4l2_format_code(const char *name)
unsigned int i;
for (i = 0; i < ARRAY_SIZE(pixel_formats); ++i) {
if (strcasecmp(pixel_formats[i].name, name) == 0)
return pixel_formats[i].fourcc;
return 0;
static struct {
const char *name;
unsigned int field;
} fields[] = {
{ "ANY", V4L2_FIELD_ANY },
{ "NONE", V4L2_FIELD_NONE },
{ "TOP", V4L2_FIELD_TOP },
{ "BOTTOM", V4L2_FIELD_BOTTOM },
{ "INTERLACED", V4L2_FIELD_INTERLACED },
{ "SEQ_TB", V4L2_FIELD_SEQ_TB },
{ "SEQ_BT", V4L2_FIELD_SEQ_BT },
{ "ALTERNATE", V4L2_FIELD_ALTERNATE },
{ "INTERLACED_TB", V4L2_FIELD_INTERLACED_TB },
{ "INTERLACED_BT", V4L2_FIELD_INTERLACED_BT },
static unsigned int v4l2_field_code(const char *name)
unsigned int i;
for (i = 0; i < ARRAY_SIZE(fields); ++i) {
if (strcasecmp(fields[i].name, name) == 0)
return fields[i].field;
return -1;
int
main (int argc,
char ** argv)
for (;;) {
int index;
int c;
c = getopt_long (argc, argv,
short_options, long_options,
&index);
if (-1 == c)
break;
switch (c) {
case 0: /* getopt_long() flag */
break;
case 'c':
count = atoi (optarg);
break;
case 'd':
dev_name = optarg;
break;
case 'f':
pixel_format = v4l2_format_code(optarg);
if (pixel_format == 0) {
printf("Unsupported video format '%s'\n", optarg);
pixel_format = V4L2_PIX_FMT_UYVY;
break;
case 'F':
field = v4l2_field_code(optarg);
if ((int)field < 0) {
printf("Unsupported field '%s'\n", optarg);
field = V4L2_FIELD_INTERLACED;
break;
case 'h':
usage (stdout, argc, argv);
exit (EXIT_SUCCESS);
case 'm':
io = IO_METHOD_MMAP;
break;
case 'o':
file_name = optarg;
break;
case 'r':
io = IO_METHOD_READ;
break;
case 's':
width = atoi (strtok (optarg, "x"));
height = atoi (strtok (NULL, "x"));
break;
case 'u':
break;
case 'z':
break;
default:
usage (stderr, argc, argv);
open_device ();
init_device ();
init_cuda ();
start_capturing ();
mainloop ();
stop_capturing ();
uninit_device ();
close_device ();
return 0;
