Hi All,
I am trying to configure a quick setup without switch so I can have my VMs using SR-IOV and talk to each other:
Windows Server 2016
MCX556A-EDAT x1
100Gbe cable x1
Method:
Connect Port1 to Port2 using the 100Gbe cable directly to form a loop
On Port 1, create a VM Switch with SR-IOV enabled in Hyper-V
Install VM1 and configure to use the VM Switch
Install VM2 and configure to use the VM Switch
Result:
VM1 can connect to host
VM2 can connect to host
Host can connect back to either VM1 or VM2
Confirmed SR-IOV is activated successfully on both VM1 and VM2
Problem:
- VM1 cannot connect to VM2
Is there any isolation for VMs if they are on SR-IOV? If I turn SR-IOV off so they fallback to VMQ, they can start connecting to each other without any problem, so it is quite obvious SR-IOV has caused them not communicating.
Or do I have to use a switch to make this setup work?
Cheers
Chris
