Hi everyone,
I just purchased a SX6018 off of ebay… I know good/bad decision but either way I need help… The pull out label is marked P/N: 100-886-230-01 so I presume this unit was manufactured for DELL? Can anyone help me identify what model this is supposed to be? MSX6018F-1SFS, MSX6018F-1BRS, MSX6018T-1SFS, or MSX6018T-1BRS??
Now on to the issues I am having with the unit… When I first power it on. The switch status LED on the front and back panel remains red for about 1 minute and 10 seconds then turns green. During that time this posts to my terminal screen:
U-Boot 2009.01 SX_PPC_M460EX SX_3.2.0330-82-EMC ppc (Feb 27 2013 - 12:13:42)
CPU: AMCC PowerPC 460EX Rev. B at 1000 MHz (PLB=166, OPB=83, EBC=83 MHz)
Security/Kasumi support
Bootstrap Option H - Boot ROM Location I2C (Addr 0x52)
Internal PCI arbiter disabled
32 kB I-Cache 32 kB D-Cache
Board: Mellanox PPC460EX Board
FDEF: No
I2C: ready
DRAM: 2 GB (ECC enabled, 333 MHz, CL3)
FLASH: 16 MB
NAND: 1024 MiB
PCI: Bus Dev VenId DevId Class Int
PCIE0: link is not up.
PCIE1: successfully set as root-complex
01 00 15b3 c738 0c06 00
Net: ppc_4xx_eth0, ppc_4xx_eth1
Hit any key to stop autoboot: 0
Waiting for PHY auto negotiation to complete… TIMEOUT !
done
ENET Speed is 10 Mbps - HALF duplex connection (EMAC0)
Using ppc_4xx_eth0 device
ping failed; host 172.17.255.252 is not alive
Loading Kernel Image … OK
ABCDEFdrv_table_install: syslog at 0x00034080 with minor 0 (DRV_SETUP)
(DRV_INIT)
drv_table_install: isrlog at 0x00034080 with minor 1 (DRV_INIT)
drv_table_install: userinterface at 0x00004db0 with minor 0 (DRV_SETUP) (DRV_I
NIT)
drv_table_install: stty0 at 0x0006eb7c with minor 0 (DRV_SETUP) (DRV_I
NIT)
drv_table_install: eth0 at 0x0006f50c with minor 0 (DRV_SETUP) (DRV_I
NIT)
drv_table_install: i2c0 at 0x0007a114 with minor 0 (DRV_SETUP) (DRV_I
NIT)
drv_table_install: i2c1 at 0x0007a114 with minor 1 (DRV_INIT)
drv_table_install: itcpip at 0x0003c400 with minor 0tcpipInit: Starting
internal TCP/IP stack.
(DRV_SETUP) (DRV_INIT)
kernel_main: Drivers installed, installing INIT process with stack size = 8192.
Bar [ 0 ] is the first memory bar
sk_init_main: Starting process based initialization - 8590.
UDP socket 3 created
TCP socket 4 created
sk_init_main: Process based initialization complete - 8590.
sk_init_main: Installing task table.
task_table_install: console at 0x00015ca4 stack 0x00452410/26624 : 4
task_table_install: inetd at 0x00035c9c stack 0x00472c10/8192 : 5
task_table_install: poll_cqs at 0x000aa98c stack 0x00458c10/8192 : 6
task_table_install: poll_ports at 0x000aaac4 stack 0x0045ac10/8192 : 7
task_table_install: env_mon at 0x000832f4 stack 0x0045ec10/8192 : 8
task_table_install: env_bin_api at 0x00014420 stack 0x00460c10/8192 : 9
task_table_install: incoming_fw_files at 0x00013e84 stack 0x00462c10/8192 : 10
task_table_install: incoming_fw_files at 0x00013e84 stack 0x00464c10/8192 : 11
sk_init_main: Task table installed. Starting tasks and exiting.
----------------------------- Board Info -----------------------------
Chasis Type : STINGRAY
Number of Ports : 18
U-Boot Revision : 3.2.330
Firmware Revision : 9.9.1030
INI file Revision : 0x21010009
SwitchOS Revision : 1.297
SwitchOS Build Date : 2013-08-02
SwitchOS Build Time : 16:34:58
SwitchOS Build Path : /emc/tdowning/ppc460_release/aug_02_2013
21:12:41 09/24/2014
Switch-X(4)>
I’m confused as to how do I login to the system to configure the unit? The user manual states “Login (from a serial terminal program) as admin and use admin as password. This starts the Mellanox configuration wizard.”
When I type in admin at the prompt the response is:
Switch-X(4)> admin
admin: Command not found.
Switch-X(4)>
So am I doing something wrong? Or is the SX6018 Defective? The person I purchased the unit from gave me a 30 day warranty which I have about 18 days to return the unit if it is defective… I should also note the LED indicators on the back panel for each of the two power supplies are off and so is the LED indicator on the fan unit. The LED indicators on the front panel for the fan, PS1, and PS2 are off as well… So that has me really confused as the fans are running and the power supplies has the unit powered up…
Please help and Thank You in advance,
RalphPeters100
