Hello everyone
I have a sx6036 running at ethernet mode, after delete the license the switch can not boot. At console shows "System is initializing!
This may take a few minutes
Modules are being configured
% A fatal internal error occurred ".
At web gui shows "System is initializing! This may take a few minutes."
Both 1 and 2 images are same failure. I have 3.6.8012.img file and can access to uboot.
Thanks advance
I logged in by admin, console shows "System is initializing!
This may take a few minutes” about 15 minutes later console shows “% A fatal internal error occurred” then login prompt again. I need to login again. It’s a endless loop.
eddies
June 15, 2020, 11:05am
3
Hi Ken,
since you deleted the license that enables the switch to run in ethernet profile. the switch can’t boot with it’s current configured ethernet profile.
if the cli will be available either install the license again or change the profile toib:
(config)# system profile ib-single-switch
Hi Eddie
The problem is I can’t use cli, because the switch hanging at "System is initializing!
% A fatal internal error occurred".
Hi Eddie
I am at Scarborough, Ontario, CANADA.
