I have followed the guide almost letter to letter, but somehow, I can’t establish a loseless link. It’s all fine and nice with “global flow control”, but PFC doesn’t seem to be working.
I see the receiver-host sending pause frames ( tx_pause_prio_3: 49732) and those frames being received by switch ( 66498 pause packets), and then pause packets generated on switch’s sender-host interface (24309 pause packets), but when checking sender’s linux interface stats, the pause packets counter is zero (rx_pause_prio_3: 0). I’m also seeing ( 93970 discard packets) on RX part of sender-host switch interface counter output.
I’m highly perplexed on what is wrong with all this setup… I’m using standard EL7 driver, using vlans with egress-qos-map configured. pfc*x params are set to 0x08 (and the counters output above was all fetched from prio 3 – thus the config was supposed to be correct).
It works totally as expected when used with global flow control – I see pause frames being sent and received as expected on both linux hosts.
Adapters are connectX-3 pro.
Another thing – when executing tcp_wrap as per docs, I’m getting:
# /usr/src/tc_wrap.py -i eth5 -u 3,3,3,3,3,3,3,3,3,3,3,3,3,3,3,3
skprio2up is availabe only for RoCE in kernels that don't support set_egress_map
Tarrfic classes are set to 8
UP 0
UP 1
UP 2
UP 3
skprio: 0
skprio: 1
skprio: 2 (tos: 8)
skprio: 3
skprio: 4 (tos: 24)
skprio: 5
skprio: 6 (tos: 16)
skprio: 7
skprio: 8
skprio: 9
skprio: 10
skprio: 11
skprio: 12
skprio: 13
skprio: 14
skprio: 15
skprio: 0 (vlan 300)
skprio: 1 (vlan 300)
skprio: 2 (vlan 300 tos: 8)
skprio: 3 (vlan 300)
skprio: 4 (vlan 300 tos: 24)
skprio: 5 (vlan 300)
skprio: 6 (vlan 300 tos: 16)
skprio: 7 (vlan 300)
UP 4
UP 5
UP 6
UP 7
UP 0
UP 1
UP 2
UP 3
UP 4
UP 5
UP 6
UP 7
Running stock EL7 kernel. Is this expected?
