I just upgraded to the 12.5 compiler (from 11.something) and when I recompile a code that works fine under the 2011 version, I get this error:
pgfortran -Kieee -Mcuda=maxregcount:32 -C -Mchkfpstk -Mchkstk -Mpgicoff -traceback -c cuda_spher_reflcoeff.f90
Lowering Error: symbol btr2$sd is an inconsistent array descriptor
PGF90-F-0000-Internal compiler error. Errors in Lowering 2 (cuda_spher_reflcoeff.f90: 777)
PGF90/x86-64 Linux 12.5-0: compilation aborted
make: *** [cuda_spher_reflcoeff.o] Error 2
The error appears in a part of the code which is unrelated to the device code.
Any idea why this appears now when it compiled fine before? As far as I can tell, the array is appropriately sized and allocated.
Thanks, Jan
