Symbol has not been explicitly declared
I’m trying to compile a device piece of code but I get the following error.
Symbol, tempallckwyr_caca, has not been explicitly declared
The ‘tempallckwyr_caca’ simbol does not exist but ‘ckwyr_caca’ is the name of a subroutine and ‘temp’ the name of a variable. What this error means?
Here is the code https://www.dropbox.com/s/q2jh58k67l46qvu/FLOW_flamelet_d.f
Many thanks
Hi ElMaskina,
The “c” in “call CKWYR_caca” at line 866 is off one space so is being treated as a continuation charater. Hence, the “temp” variable form the previous line is being prepended to “all”.
Note that “CKWYR_caca” is device function so can’t be called from host code.
Hope this helps,
Mat
