I wrote a program with CPU in C++
and then i would like to make some change therefore it can be run in GPU
Although no error in prompt after compiling, break point is triggered after some code is run.
Then i found that all variables declared in the function are actually not declared. When i put it in Watch, it indicated that the symbol is not found.
However, this function is not for GPU.
For example:
void add_all(int a)
int i = a;
char * temp = (char*)malloc(sizeof(char)*i);
then it said that “i” and temp is not found.
Could anyone give me a solution on this??
