Hi,there
I have the following pipeline used in openCV on Jetson Nano
v4l2src device=/dev/video0 io-mode=2 extra-controls=s,exposure_auto=1,contrast=0,exposure_absolute=1 ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw, format=RGBA ! videoconvert ! video/x-raw,format=BGR ! appsink drop=1
It works well but when the program is finish and call videoCapture.release(), I got the folowing error
./build/bin/gstreamer_demo: symbol lookup error: /usr/lib/aarch64-linux-gnu/tegra/libnvmmlite_video.so: undefined symbol: NvMMLiteBlockSendEOS
I checked the libnvmmlite_video.so is exist, and my nv_tegra_release content is
# R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
CUDA version is 10.2
Any advice?
Are you able to upgrade to later version such as Jetpack 4.6 or 4.6.1 and try again?
Thanks for your replay.
I have upgraded to Jetpack4.6.1, here is the new nv_tegra_release content:
# R32 (release), REVISION: 7.1, GCID: 29818004, BOARD: t210ref, EABI: aarch64, DATE: Sat Feb 19 17:05:08 UTC 2022
But the error is same
We have tried this string and don’t see any issue:
Set camera decoder in OpenCV on Jetson Nano - #8 by DaneLLL
Please give it a try.
I’ve tried the following string but the error still occurred when VideoCapture release was called
v4l2src device=/dev/video0 io-mode=2 extra-controls=s,exposure_auto=1,contrast=0,exposure_absolute=1 ! jpegparse ! nvv4l2decoder mjpeg=1 ! nvvidconv ! video/x-raw, format=RGBA ! videoconvert ! video/x-raw,format=BGR ! appsink
Any other solutions?
Should I re-setup my device? Install the latest jp461 sd-card image?
Please clean cache and check if it helps:
$ rm .cache/gstreamer-1.0/registry.aarch64.bin
If the issue is still present, may try either USB camera and see if it works. Generally USB cameras support MJPEG and can be a reference camera.
The error still occurred.
Is this related with the OpenCV? I used the version 4.4.0.
I’ll try OpenCV 4.5.x and update this post if have some result
Thanks for your time
kayccc
#9
Have you tried with OpenCV 4.5.x?
Is this still an issue to support?
I’ve tried OpenCV 4.5.1, but it still not worked, same error.
We suggest you re-install the system image and SDK components. By default there is a 4.1.1 package.
