I’ve hit a rather strange problem relating to code optimization with MSVC as the host compiler. I have a small lookup table (a couple of kilobytes) I need to load into the constant memory of the GPU, which works gloriously in debug mode, but cudaGetSymbolAddress
fails with cudaErrorInvalidSymbol
in release. After some digging around (assuming my code is correct) I narrowed down the problem to optimization flags passed to the host compiler during the nvcc
device compilation pass. It appears as if the global variable is stripped whenever I pass any optimization flags for the host compiler, probably during the DSE/DCE optimizer pass(es). For what is worth the pragma
to disable the optimizations (see code bellow) doesn’t appear to change anything for me.
I am building by generating a separate relocatable device code before I link everything together, if it matters (which I don’t believe it should).
The code which is giving me headaches is as follows:
data.cpp
#include "data.h"
#pragma optimize("", off)
MM_CUDA_CONSTANT MyNamespace::Data GlobalData;
namespace MyNamespace {
bool Data::initialize() noexcept
H.initialize();
F.initialize();
#if defined(MM_CUDA)
void * dataSymbol = nullptr;
cudaError_t status = cudaGetSymbolAddress(&dataSymbol, GlobalData);
if (status != cudaSuccess) {
log("Couldn't get symbol address off the CUDA device!");
return false;
status = cudaMemcpy(dataSymbol, this, sizeof(MyNamespace::Data), cudaMemcpyHostToDevice);
log("Couldn't intialize the memory on CUDA device!");
return false;
#endif
return true;
MM_CUDA_LOCAL const Data & data() noexcept
return GlobalData;
Where the header is only declaring the (trivially constructible POD) struct:
#include "fdata.h"
#include "hdata.h"
struct Data
HData H;
FData F;
bool initialize() noexcept;
MM_CUDA_LOCAL const Data & data() noexcept;
The macro MM_CUDA_LOCAL
expands to __device__ __host__
, whereas MM_CUDA_CONSTANT
is equivalent to __constant__
. As you can probably tell my code is “mixed-mode”, allowing to be compiled with or without CUDA support. In any case, here’s the compile line I prepare and use (from qmake
nvcc.exe -arch=native -m64 --no-exceptions -DQ_NVCC -x cu -std c++17 -I. (... more include paths ...) -Xcompiler -nologo,-Zc:wchar_t,-FS,-Zc:rvalueCast,-Zc:inline,-Zc:strictStrings,-Zc:throwingNew,-Zc:referenceBinding,-Zc:__cplusplus,-O2,-Zi,-MD,-std:c++17,-DUNICODE,-D_UNICODE,-DWIN32,-D_ENABLE_EXTENDED_ALIGNED_STORAGE,-DWIN64,-DMM_MSVC,-DMM_WITH_SELFTEST,-DMM_CUDA,-DNDEBUG,-DQ_NVCC --device-c data.cpp -o release\data.cpp.obj
Forcing -O2
to -Od
makes the above code resolve the symbol and copy the data.
MSVC version is: 19.28.29337
NVCC version is: 11.8.89
So the question is:
Is this a bug, or am I doing something wrong?
Kind regards,
Konstantin.
