Our customized carrier board for Orin 32G module uses vmm5320 DP hub to split DP2 into one DP and one HDMI port. We can’t get correct display under two test cases.
[Test case 1-HDMI replug]
0101. When DP and HDMI are connected, then power on. Both of them can’t see the login GUI.(fail)
0102. If we unplug the HDMI, the DP displays the login GUI.(pass)
0103. If we plug the HDMI in, both of them display correctly.(pass)
Vender use EzAux app to analyze.
0101. The HDMI of Orin is at 594MHz and DSC OFF state, but it only allocate 16 slots which causes the bandwidth is not enough , it should allocate 36 slots to fulfill this state.
0103.The HDMI of Orin is DSC ON state, and it allocates 36 slots.Both of DP and HDMI can display correctly.
[Test case 2 - DP replug]
0201. When DP and HDMI are connected, then power on. Both of them can’t see the login GUI.(fail)
0202. If we unplug the DP, the HDMI displays the login GUI.(pass)
0203. If we plug the DP in, both of them can’t see the login GUI.(fail)
0202. The HDMI of Orin is at 594MHz and DSC On state, it allocates 16 slots which is enough to display correctly.
- The HDMI of Orin is changed to DSC Off state, and 16 slots are enough to display correctly.
A.The “0101” and “0203” are incorrect, please help to check it.
B.Could we change the Jetson modules(Orin,Orin Nx, and Orin Nano) to DSC off ?
Logs.zip (2.8 MB)
