sync aurix and tegra
Can anybody tell me that the sync between aurix and tegra A is right or not? the the value following “+/-” was so big even after a while of syncing. The corresponding value for syncing tegra B is only 0-3. Thanks in advance!
ptp4l[3510.445]: delay filtered 8910 raw 9039
ptp4l[3510.494]: port 1: received PDELAY_RESP without timestamp
ptp4l[3510.538]: port 1: received PDELAY_REQ without timestamp
ptp4l[3510.786]: port 1: received PDELAY_RESP without timestamp
ptp4l[3510.797]: rms 770596 max 1326362 freq -7417675 +/- 908180 delay 7075 +/- 1407
ptp4l[3510.941]: port 1: delay timeout
ptp4l[3510.951]: delay filtered 8910 raw 19646
ptp4l[3511.038]: port 1: received PDELAY_REQ without timestamp
ptp4l[3511.311]: port 1: received PDELAY_RESP without timestamp
ptp4l[3511.443]: port 1: delay timeout
ptp4l[3511.450]: delay filtered 6824 raw 2749
ptp4l[3511.538]: port 1: received PDELAY_REQ without timestamp
ptp4l[3511.585]: port 1: received PDELAY_RESP without timestamp
ptp4l[3511.787]: port 1: received PDELAY_RESP without timestamp
ptp4l[3511.944]: port 1: delay timeout
ptp4l[3511.952]: delay filtered 6824 raw 8807
ptp4l[3512.038]: port 1: received PDELAY_REQ without timestamp
ptp4l[3512.312]: port 1: received PDELAY_RESP without timestamp
ptp4l[3512.410]: rms 1595447 max 2659974 freq -6568437 +/- 2192489 delay 7519 +/- 983
ptp4l[3512.446]: port 1: delay timeout
ptp4l[3512.455]: delay filtered 8794 raw 27953
ptp4l[3512.538]: port 1: received PDELAY_REQ without timestamp
ptp4l[3512.682]: port 1: received PDELAY_RESP without timestamp
Never mind. Problem is solved.
