Sync data between four I2S
There are 4 I2S interface, I will use 3 of them. I want to make them receive data at the same time, they must sync in the hardware level. Is there any configuration that I can use to make the I2S interfaces sync in hardware level? I can not use software sync.
As far as I know, there is only one I2S controller in TX1, it can’t handle multi streams simultaneously in hardware level.
