The complete pipeline diagram is as follows:
pipeline.zip (468.7 KB)
Here is my code. Our intention is to map the detection results of 18 sources to the first source, but when I turn on the sync inputs option, the detection box keeps flashing. Through printing, I found that sometimes batch_sta may be incomplete. According to nvstreammux’s instructions, when the synchronization frame arrival time timeout is enabled, incomplete batches will indeed be pushed. However, when I finally tiled it, I found that the batch_sta I obtained will be mapped to the first source, with a green box. In addition, there is also data that has not been obtained by me, with a red box.
static GstPadProbeReturn tracker_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info, gpointer u_data){
GstBuffer *buf = (GstBuffer *) info->data; //getting buffer
NvDsObjectMeta *obj_meta_src0 = NULL;
NvDsMetaList * l_frame = NULL;
NvDsMetaList * l_obj_src0 = NULL;
NvDsFrameMeta *panorama_frame = NULL;
NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf); //extracting batch meta
std::unordered_map<guint, NvDsFrameMeta*> frame_map;
for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;l_frame = l_frame->next) {
NvDsFrameMeta *frame_meta = (NvDsFrameMeta *)l_frame->data;
frame_map[frame_meta->source_id] = frame_meta;
// g_print("src_0 %d,src_1 %d,src_2 %d,src_3 %d,src_4 %d,src_5 %d,src_6 %d,src_7 %d,src_8 %d,src_9 %d,src_10 %d,src_11 %d,src_12 %d,src_13 %d,src_14 %d,src_15 %d,src_16 %d,src_17 %d,src_18 %d\n",frame_map.count(1),frame_map.count(2),frame_map.count(3),frame_map.count(4),frame_map.count(5),frame_map.count(6),frame_map.count(7),frame_map.count(8),frame_map.count(9),frame_map.count(10),frame_map.count(11),frame_map.count(12),frame_map.count(13),frame_map.count(14),frame_map.count(15),frame_map.count(16),frame_map.count(17),frame_map.count(18));
if(frame_map.count(0))
panorama_frame = frame_map[0];
nvds_clear_obj_meta_list(panorama_frame, panorama_frame->obj_meta_list);
nvds_clear_display_meta_list(panorama_frame, panorama_frame->display_meta_list);
for (int src_id = 1; src_id <= 18; ++src_id) {
if (frame_map.count(src_id)) {
transform(batch_meta, frame_map[src_id], panorama_frame);
return GST_PAD_PROBE_OK;
void transform(NvDsBatchMeta *batch_meta,NvDsFrameMeta * frame_meta_src0,NvDsFrameMeta * frame_meta_src1){
for (NvDsMetaList *l_obj_src0 = frame_meta_src0->obj_meta_list; l_obj_src0 != NULL;l_obj_src0 = l_obj_src0->next) {
//getting object metadata
obj_meta_src0 = (NvDsObjectMeta *) (l_obj_src0->data);
//acquiring object metadata
NvDsObjectMeta *new_obj_meta = nvds_acquire_obj_meta_from_pool(batch_meta);
//copying to new object
nvds_copy_obj_meta(obj_meta_src0,new_obj_meta);
obj_meta_src0->rect_params.border_color.red=0;
obj_meta_src0->rect_params.border_color.green=1;
obj_meta_src0->rect_params.border_color.blue=0;
obj_meta_src0->rect_params.border_width=5;
//applying transformation
apply_homography_obj_meta(frame_meta_src0->source_id,new_obj_meta);
//adding modified object metadata to the frame of source1
nvds_add_obj_meta_to_frame(frame_meta_src1,new_obj_meta,NULL);
This is a screenshot of the problem that occurred:
Screenshot from 2025-03-28 11-26-18.zip (5.8 MB)
