I have been playing a bit with __syncthreads and don’t really understand why using it in the following code improves the performance of the algorithm.
// part of the __device__ function which computes a range of AES expanded keys.
unsigned int s_expanded[(176/4)];
s_expanded[0]=g_key[0+(where*4)];
s_expanded[1]=g_key[1+(where*4)];
s_expanded[2]=g_key[2+(where*4)];
s_expanded[3]=g_key[3+(where*4)];
__syncthreads();
for ( i = 4; i < 176/4; i++ )
temp = s_expanded[i-1];
if ( ( i % 4 ) == 0 )
temp =KeyScheduleCore ( temp, rconIter );
rconIter ++;
__syncthreads();
temp = temp ^ s_expanded[i-4 ];
__syncthreads();
s_expanded[i] = temp;
__syncthreads();
__syncthreads();
As it can be seen there is not even need for syncthreads as there is no thread communications.
The speed improvements after putting syncthreads are quite big, more than 20%.
