使用syncsensor 示例 在 L4T 35.4.1环境下实现4个相机同步,获取图像一样,都是camera0
我是用 AGX ORIN 同步捕获3840x2160 30fps csi-2,通过修改sample/syncSensor, 从2通道修改为4通道,但当通道为4时,程序获取到的图像都是camera0的图像,改为3个通道,可以正常获取到图像,Argus库是否无法支持1个会话采集一组4个的同步相机,我可以通过修改什么实现同步获取四个相机图像?
hello 1520227351,
this is known issue, please see-also forum discussion thread, Topic 230259.
Currently, we support up-to 3 camera as synchronized cameras in a single session.
hence, please try running with 2+2 for your 4-camera scenario.
