syntax error causes compiler to hang indefinitely
The following code contains a misspelling of the word “module” which causes the pgf90/95 compiler to hang. We are running PGI 6.1-3 on a Fedora Core 3 system, glibc version 2.3.5.
! modle.f90
! Hangs PGI compiler because of mispelling of "module"
modle fooModule
contains
integer function setval()
implicit none
real :: r
setval = 5.0
end function
end module
program foobar
use fooModule
implicit none
real :: rval
rval = setval()
write(*,*) 'rval = ', rval
stop
end program
Hi David,
The problem has been added as TPR#3848 and has been assigned to an compiler engineer for review.
Thank you for the report,
Mat
