Syntax error when compiling device tree
I am currently trying to recompile the device tree after some concerns were brought up regarding the source of our original device tree.
The file tegra186-tx2nx-lt6911uxc.dtsi was added as an included file in hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-quill-common.dtsi. When I try to compile the device tree using the make command make -C kernel/kernel-4.9/ ARCH=arm64 O=$TEGRA_KERNEL_OUT LOCALVERSION=-tegra CROSS_COMPILE=${TOOLCHAIN_PREFIX} -j$(nproc) dtbs I get the following syntax errors:
Error: /opt/Linux_for_Tegra/source/public/kernel/kernel-4.9/../../hardware/nvidia/platform/t18x/common/kernel-dts/t18x-common-platforms/tegra186-tx2nx-lt6911uxc.dtsi:13.38-39 syntax error
FATAL ERROR: Unable to parse input tree
I read this as there being an issue on line 13, which is where I set the reset GPIO.
reset-gpio = <&tegra_main_gpio TEGRA186_MAIN_GPIO(N, 1) GPIO_ACTIVE_LOW>;
Is this the incorrect syntax, or am I missing something else?
hello miles.heaton,
it’s due to the property is missing while compiling the sources.
please check you’ve include the dtsi files correctly, thanks
That definitely makes sense. I went and included what I expected to be the relevant gpio files for the TX2 NX and tried recompiling, but ran into similar errors. So I’m not certain what include file I could be missing.
I captured the errors into the file dtb_compile_errors.txt (7.3 KB)
Please see the full dtsi file tegra186-tx2nx-lt6911uxc.dtsi:
#define LT6911_EN "okay"
#include <dt-bindings/gpio/gpio.h>
#include <dt-bindings/gpio/tegra186-gpio.h>
        i2c@3180000 {
                clock-frequency = <100000>;
                lt6911uxc_a@2b {
                        compatible = "nvidia,lt6911uxc";
                        reg = <0x2b>;
                        status = "okay";
                        devnode = "video0";
                        /* Reset */
                        /* Interrupt */
                        interrupt-parent = <&tegra_main_gpio>;
                        interrupts = <&tegra_main_gpio TEGRA186_MAIN_GPIO(E, 2) IRQ_TYPE_LEVEL_HIGH>;
                        mclk = <&tegra_main_gpio TEGRA186_MAIN_GPIO(J, 3)>;
                        set_mode_delay_ms = "5000";
                        port@0 {
                                ret = <0>;
                                status = "okay";
                                hdmi2csi_lt6911_out0: endpoint {
                                        status = "okay";
                                        port-index = <0>;
                                        bus-width = <4>;
                                        remote-endpoint = <&hdmi2csi_csi_in0>;
        host1x {
                /* Delete existing VI node to avoid conflicts */
        /delete-node/ vi;
                vi@15c10000 {
                        num-channels = <1>;
                        status = LT6911_EN;
                        ports {
                                #address-cells = <1>;
                                #size-cells = <0>;
                                port@0 {
                                        status = LT6911_EN;
                                        reg = <0>;
                                        hdmi2csi_vi_in0: endpoint {
                                                status = LT6911_EN;
                                                port-index =<0>;
                                                bus-width = <4>;
                                                remote-endpoint = <&hdmi2csi_csi_out0>;
                nvcsi@15a00000 {
                        num-channels = <1>;
                        #size-cells = <0>;
                        status = LT6911_EN;
                        channel@0 {
                                status = LT6911_EN;
                                reg = <0>;
                                discontinuous_clk = "no";
                                ports {
                                        #size-cells = <0>;
                                        port@0 {
                                                status = LT6911_EN;
                                                reg = <0>;
                                                hdmi2csi_csi_in0: endpoint@0 {
                                                        status = LT6911_EN;
                                                        port-index = <0>;
                                                        bus-width = <4>;
                                                        remote-endpoint = <&hdmi2csi_lt6911_out0>;
                                        port@1 {
                        status = LT6911_EN;
                        reg = <1>;
                        hdmi2csi_csi_out0: endpoint@1 {
                            status = LT6911_EN;
                            remote-endpoint = <&hdmi2csi_vi_in0>;
        tegra-camera-platform {
                compatible = "nvidia, tegra-camera-platform";
                * Physical settings to calculate max ISO BW
                * num_csi_lanes = <>;
                * Total number of CSI lanes when all cameras are active
                * max_lane_speed = <>;
                * Max lane speed in Kbit/s
                * min_bits_per_pixel = <>;
                * Min bits per pixel
                * vi_peak_byte_per_pixel = <>;
                * Max byte per pixel for the VI ISO case
                * vi_bw_margin_pct = <>;
                * Vi bandwidth margin in percentage
                * max_pixel_rate = <>;
                * Max pixel rate in Kpixel/s for the ISP ISO case
                * isp_peak_byte_per_pixel = <>;
                * Max byte per pixel for the ISP ISO case
                * isp_bw_margin_pct = <>;
                * Isp bandwidth margin in percentage
                num_csi_lanes = <8>;
                max_lane_speed = <2500000>;
                min_bits_per_pixel = <16>;
                vi_peak_byte_per_pixel = <3>;
                vi_bw_margin_pct = <25>;
                isp_peak_byte_per_pixel = <3>;
                isp_bw_margin_pct = <25>;
                status = LT6911_EN;
                * The general guideline for naming badge_info contains 3 parts, and is as follows,
                * The first part is the camera_board_id for the module; if the module is in a FFD
                * platform, then use the platform name for this part.
                * The second part contains the position of the module, ex. “rear” or “front”.
                * The third part contains the last 6 characters of a part number which is found
                * in the module's specsheet from the vender.
                modules {
                        module0 {
                                status = LT6911_EN;
                                badge = "hdmi2csi_left_6911";
                                position = "left";
                                orientation = "1";
                                drivernode0 {
                                        /* Declare PCL support driver (classically known as guid)  */
                                        pcl_id = "v4l2_sensor";
                                        /* Driver v4l2 device name */
                                        devname = "lt6911uxc 2-002b";
                                        /* Declare the device-tree hierarchy to driver instance */
                                        proc-device-tree = "/proc/device-tree/i2c@3180000/lt6911uxc_a@2b";
hello miles.heaton,
these two is not necessary.
as you can see,
it’s tegra186-soc-base.dtsi to define this tegra_main_gpio.
for example,
        tegra_main_gpio: gpio@2200000 {
                compatible = "nvidia,tegra186-gpio";
The above solution didn’t work for me.
From what I can tell, the issue was due to where the function calls for TEGRA186_MAIN_GPIO() were located.
By defining those function calls at the top of the file (see the #define section in the code below) as different names, the compile went through without issue. Commented out in the code are the original definitions (reset-gpio, interrupts, and mclk).
@JerryChang I did not see any note in the documentation specifying that GPIO pins should be defined outside of the main code body in a .dtsi file, so I don’t know if this is a bug or just some idiosyncrasy I worked around. Do you have any insight as to whether this is expected functionality?
#include <dt-bindings/media/camera.h>
#define RSTN    TEGRA_MAIN_GPIO(N, 1)
#define INTR    TEGRA_MAIN_GPIO(E, 2)
#define LRCK    TEGRA_MAIN_GPIO(J, 3)
        i2c@3180000 {
                lt6911uxc_a@2b {
                        reg = <0x2b>;
                        status = "okay";
                        devnode = "video0";
                        /* Reset */
                        //reset-gpio = <&tegra_main_gpio TEGRA186_MAIN_GPIO(N, 1) GPIO_ACTIVE_LOW>;
                        reset-gpio = <&tegra_main_gpio RSTN GPIO_ACTIVE_LOW>;
                        /* Interrupt */
                        //interrupts = <TEGRA186_MAIN_GPIO(E, 2) IRQ_TYPE_LEVEL_HIGH>;
                        interrupts = <INTR IRQ_TYPE_LEVEL_HIGH>;
                        //mclk = <TEGRA186_MAIN_GPIO(J, 3)>;
                        mclk = <LRCK>;
hello miles.heaton,
I don’t understand your point.
syntax errors basically caused by error definition or property is missing.
