I have questions regarding SYS_RESET_N, especially in power up and down sequence.
As documented in Xavier OEM .pdf doc, SYS_RESET_N is a bi-direction signal connected to NRST_IO of PMIC. So, it can be driven from carrier to SoM to reset SoM. And it be can driven from SoM to carrier to reset devices on carrier.
- In OEM doc, in the power up sequence diagram, the last step is releasing SYS_RESET_N. Is this driven by SoM (PMIC) which tells carrier that SoM is up? Or is this driven by carrier to reset SoM?
- Same in the power down sequence. At the beginning SYS_RESET_N is asserted. Is this driven by SoM (PMIC) to tell carrier that SoM is down? Or is this driven by carrier?
- There is also a SYS_RESET_N input on Xavier SoC according to TRM. I am curious how these are connected internally? (SoC(SYS_RESET_N) <— PMIC(NRST_IO) <—> carrier).
So, when carrier drives SYS_RESET_N on SoM, PMIC will then drives SYS_RESET_N on SoC?
Thanks,
Shuo
