SYS_VIN_HV and SYS_VIN_MV Power ratio
Does nominal consumption of SYS_VIN_HV and SYS_VIN_MV follow the same ratio of maximum ratings?
I understand the max power should be no more than 60W, I want to find out what are the expected current for the two rails?
Thank you,
No, the ratio is not fixed. It depends on use case.
Hi Trumany,
Thank you for your response.
Would you be able to provide or direct me to any information about the typical consumptions of those two supplies? i.e. in 35W operationg mode (mode 2).
All we need is an estimate for thermal design, so any information on the nominal power distribution would be helpful.
Thank you,
You can start from this link: Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux<br/>Developer Guide 34.1 documentation
