I’m trying to use ensemble model in deepstream-triton with pytorch & python backend. The pipeline is:
Pre-processing → Infer-segmentation → Post-processing
- Pre-processing Configs
backend: "python"
max_batch_size : 0
input [
data_type: TYPE_UINT8
dims: [-1, 3, 128, 64]
output [
data_type: TYPE_FP32
parameters: {
key: "EXECUTION_ENV_PATH",
value: {string_value: <path-to-env>}
- Infer Config
platform: "pytorch_libtorch"
max_batch_size: 0
input [
output [
dims: [-1, 128, 64, 6]
- Post-processing Config
backend: "python"
max_batch_size : 0
input [
output [
data_type: TYPE_INT32
dims: [-1, 4, 3, 3]
parameters: {
- Ensemble Config
platform: "ensemble"
max_batch_size: 0
input [
output [
dims: [-1, 4, 3, 3]
ensemble_scheduling {
step [
model_name: "pre_segment_person"
model_version: -1
input_map {
key: "raw_images"
value: "raw_images"
output_map {
key: "segment_inputs"
value: "segment_inputs"
model_name: "infer_segment_person"
model_version: -1
input_map {
key: "input__0"
output_map {
key: "output__0"
value: "segment_outputs"
model_name: "post_segment_person"
model_version: -1
input_map {
key: "raw_images"
value: "raw_images"
input_map {
key: "segment_outputs"
output_map {
key: "human_colors"
value: "human_colors"
- Deepstream-triton Config
infer_config {
unique_id: 1
gpu_ids: [0]
max_batch_size: 0
backend {
inputs: [ {
outputs: [
{name: "human_colors"}
trt_is {
model_name: "ens_segment_person"
version: -1
model_repo {
root: "/deepstream/triton-server/models"
strict_model_config: false
log_level: 1
preprocess {
network_format: IMAGE_FORMAT_RGB
tensor_order: TENSOR_ORDER_LINEAR
tensor_name: "raw_images"
maintain_aspect_ratio: 0
normalize {
scale_factor: 1.0
channel_offsets: [0, 0, 0]
postprocess {
classification {
custom_parse_classifier_func: "NvDsInferParseCustomPersonColors"
extra {
copy_input_to_host_buffers: false
custom_lib {
path : "/deepstream/nvdsinfer_custom_impl_Yolo/libnvdsinfer_custom_impl_Yolo.so"
output_control {
output_tensor_meta: false
detect_control {
default_filter {
bbox_filter {
min_width: 32
min_height: 32
I also built custom classification parser name NvDsInferParseCustomPersonColors
// Shape of output array is [1,4,3,3]
for (int k = 0; k < 4; k++){
if (k != 0) attrString += ",";
attrString += "(";
attrString += std::to_string(human_colors[cc]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 1]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 2]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 3]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 4]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 5]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 6]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 7]);
attrString += ",";
attrString += std::to_string(human_colors[cc + 8]);
attrString += ")";
cc += 9;
NvDsInferAttribute person_color_attr;
person_color_attr.attributeIndex = 1;
person_color_attr.attributeValue = 2;
person_color_attr.attributeConfidence = 1.0;
person_color_attr.attributeLabel = strdup(attrString.c_str());
attrList.push_back(person_color_attr);
if(log_enable != NULL && std::stoi(log_enable)) {
std::cout << "Person Color C++ Parser: " << person_color_attr.attributeLabel << " attrString: " << attrString.c_str() << std::endl;
However, i got this error after several normally running steps:
Person colors python backend: [[[[ 58 251 62]
[250 57 79]
[ 55 74 54]]
[[ 45 64 55]
[ 62 53 252]
[251 45 65]]
[[ 95 90 184]
[245 105 119]
[ 86 251 89]]
[[ -1 -1 -1]
[ -1 -1 -1]
[ -1 -1 -1]]]]
Person Color C++ Parser: (58,251,62,250,57,79,55,74,54),(45,64,55,62,53,252,251,45,65),(95,90,184,245,105,119,86,251,89),(-1,-1,-1,-1,-1,-1,-1,-1,-1) attrString: (58,251,62,250,57,79,55,74,54),(45,64,55,62,53,252,251,45,65),(95,90,184,245,105,119,86,251,89),(-1,-1,-1,-1,-1,-1,-1,-1,-1)
Person colors python backend: [[[[ 90 251 92]
[109 91 247]
[250 86 106]]
[[247 60 95]
[ 64 251 53]
[ 82 64 251]]
[[252 115 115]
[115 116 93]
[115 93 252]]
[[ -1 -1 -1]
[ -1 -1 -1]
[ -1 -1 -1]]]]
Person Color C++ Parser: (90,251,92,109,91,247,250,86,106),(247,60,95,64,251,53,82,64,251),(252,115,115,115,116,93,115,93,252),(-1,-1,-1,-1,-1,-1,-1,-1,-1) attrString: (90,251,92,109,91,247,250,86,106),(247,60,95,64,251,53,82,64,251),(252,115,115,115,116,93,115,93,252),(-1,-1,-1,-1,-1,-1,-1,-1,-1)
Person colors python backend: [[[[199 97 88]
[ 80 250 92]
[ 86 77 252]]
[[ 66 67 252]
[ 60 248 68]
[248 86 68]]
[[252 68 71]
[ 68 252 67]
[ 70 68 252]]
[[246 82 81]
[ 69 250 84]
[ 69 67 251]]]]
Person Color C++ Parser: (199,97,88,80,250,92,86,77,252),(66,67,252,60,248,68,248,86,68),(252,68,71,68,252,67,70,68,252),(246,82,81,69,250,84,69,67,251) attrString: (199,97,88,80,250,92,86,77,252),(66,67,252,60,248,68,248,86,68),(252,68,71,68,252,67,70,68,252),(246,82,81,69,250,84,69,67,251)
deepstream-app: malloc.c:2379: sysmalloc: Assertion `(old_top == initial_top (av) && old_size == 0) || ((unsigned long) (old_size) >= MINSIZE && prev_inuse (old_top) && ((unsigned long) old_end & (pagesize - 1)) == 0)' failed.
Person colors python backend: [[[[243 244 242]
[236 207 221]
[209 226 244]]
[[246 247 246]
[240 214 226]
[217 233 244]]
[[ -1 -1 -1]
[ -1 -1 -1]
[ -1 -1 -1]]
[[ -1 -1 -1]
[ -1 -1 -1]
[ -1 -1 -1]]]]
Aborted (core dumped)
0304 09:15:26.671987 6674 pb_stub.cc:737] Non-graceful termination detected. 0304 09:15:26.671985 6590 pb_stub.cc:737] Non-graceful termination detected. 0304 09:15:26.671994 6754 pb_stub.cc:737] Non-graceful termination detected.
But, when i tried to hard code with shorter string, the error disappear
std::string tmp_string = "test";
person_color_attr.attributeLabel = strdup(tmp_string.c_str())
• Hardware Platform (Jetson / GPU): A100 GPU
• DeepStream Version: 6.0
• DeepStream Container: 6.0-triton
