I came across an error with the architecture of my system. When I tried to run JetPack-LT4-2.1-linux-x64.run, I got a popup that said: “JetPack must be run on x86_64 HOST platform. Detected platform”
When I type the command arch into the terminal, I get armv7l. In order to download the JetPack, I need x86_64. I did some research and didn’t come across any information about how to switch from 32-bit to 64-bit so I decided to start over, following the instructions of this link: How to Reinstall the Original File System on Jetson TK1.
I got an error at step 2 but I tried 3 and 4 anyways:
(2) Get Jetson TK1 board support package aka BSP (called Tegra124LinuxR19.2.0_armhf.tbz2)
wget https://developer.nvidia.com/sites/default/files/akamai/mobile/files/L4T/Tegra124_Linux_R19.2.0_armhf.tbz2
(3) Get sample file system file (called TegraLinuxSample-Root-FilesystemR19.2.0armhf.tbz2)
wget https://developer.nvidia.com/sites/default/files/akamai/mobile/files/L4T/Tegra_Linux_Sample-Root-Filesystem_R19.2.0_armhf.tbz2
(4) Extract the BSP tarball
sudo tar xpf Tegra124_Linux_R19.2.0_armhf.tbz2
This didn’t solve the issue and now, when I startup the Jetson, the NVIDIA specific first-boot script fails.
How do I restart my system and set it up for 64 bit processing? Thank you!
