So this issue is reproduced when you configuire jetson io and then upgrade.
Could you tell us what pin did you configure in jetson-io?
I set these pins: pwm0 (32), i2c (27, 28).
I think the problem is that jetson-io creates custom dtb (tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb) that is not compatible with the new version of L4T. Probably the specific pin settings don’t matter.
LABEL JetsonIO
MENU LABEL Custom 40-pin Header Config
LINUX /boot/Image
FDT /boot/tegra210-p3448-0000-p3449-0000-b00-user-custom.dtb
INITRD /boot/initrd
Also, I had this problem with some previous updates of L4T. Some updates were successful, some were not. Earlier I had to create a new SD image with the current version of L4T and restore my project again.
Let me put the problematic log from your text file here.
18:17:46:348] [ 0.000000] Preemptible hierarchical RCU implementation.␍␊
[18:17:46:348] [ 0.000000] ⇥ Build-time adjustment of leaf fanout to 64.␍␊
[18:17:46:376] [ 0.000000] ⇥ RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.␍␊
[18:17:46:376] [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4␍␊
[18:17:46:376] [ 0.000000] NR_IRQS:64 nr_irqs:64 0␍␊
[18:17:46:376] [ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller␍␊
[18:17:46:402] [ 0.000000] t210 clock and reset probe␍␊
[18:17:46:402] [ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1␍␊
[18:17:46:424] [ 0.000000] clk_cbus_recalc_rate: no gbus parent␍␊
[18:17:46:448] [ 0.000000] clk_cbus_recalc_rate: no gbus parent␍␊
[18:17:46:448] [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).␍␊
[18:17:46:448] [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns␍␊
[18:17:46:476] [ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns␍␊
[18:17:46:476] [ 0.010048] Console: colour dummy device 80x25␍␊
[18:17:46:476] [ 0.014705] console [tty0] enabled␍␊
[18:17:46:499] [ 0.018221] bootconsole [uart8250] disabled␍␊
Hi lich.mk,
Using default JP-4.4 GA (r32.4.3) image, I don’t see the i2c (27,28) pins, where are you set those two pins?
Yes, I was wrong. I configured only pin 32.
Hi lich.mk,
I think we find the cause of this issue.
Thus, with (1) +(2), it caused the system not able to boot up. You can only re-generate dtb after you upgrade to jp4.4.1.
