I am trying to just flash “Tegra b” on my DrivePX2. The steps I followed is
Put the “Tegra b” into recovery mode from Aurix
shell> tegrarecovery b on
shell> tegrareset b
On the host “cd vibrante-t186ref-foundation/utils/scripts/bootburn”
./bootburn.sh -b p2379c01-t186b -l
(The above command flashes the Tegra b)
reset the Tegra b from recovery mode through Aurix
shell> tegrarecovery b off
shell> tegrareset b
“Tegra b” boots up
On the UART console of “Tegra b” it hangs after the following output
OK ] Started Getty on tty1.
target=drive-px2-b, card=, kernel=4.4.38-rt49-tegra
[ OK ] Started CUPS Scheduler.
[ OK ] Started Board specific initialization.
[ OK ] Reached target Companion services for Nvidia Tegra.
Starting devOTA setup…
devOTA service started …
Launching devOTA setup …
Current PDK version is 4.1.8.0.9387945.9408590
SSL cert hash files missing! Performing rehash
[ 36.888719] bash[2048]: starting Aurix FW checking…
[ 36.896668] bash[2048]: Checking arguments…
[ 36.904607] bash[2048]: Aurix OTA is only valid for DrivePX2 Tegra A and ACR
[ 36.917091] bash[2048]: Created symlink from /etc/systemd/system/nv_aurix_check_fw.service to /dev/null.
I can ssh into “Tegra b”, but console is hung as shown in step 4
But for the recent try, I followed the link that you referred. I still see the same issue.
Put “Tegra b” into recovery mode from Aurix
shell> tegrareset b
On the host, executed the following commands
• For P2379 Tegra B:
cd /vibrante-t186ref-foundation/
make -f Makefile.bind BOARD=p2379c01-t186b PCT=linux
./utils/scripts/bootburn/bootburn.sh -b p2379c01-t186b -H
Connect to the “Tegra b” UART /dev/ttyUSB6, and removed the board from forced recovery mode
shell> tegrareset b
The console is hung after the following output
[ 39.096554] bash[2012]: starting Aurix FW checking…
[ 39.104678] bash[2012]: Checking arguments…
[ 39.112706] bash[2012]: Aurix OTA is only valid for DrivePX2 Tegra A and ACR
[ 39.117341] bash[2012]: Created symlink from /etc/systemd/system/nv_aurix_check_fw.service to /dev/null.
[ 124.991502] NOHZ: local_softirq_pending 80
Solved the issue. I was just working on Console. Since it was hung on startx, I hooked up a monitor to the HDMI port of Tegra b device and completed the initial tasks and everything looks good
