System gets frozen from time to time
after some recent update, I experienced lots of system freeze or UI hang issue when I use a USB type-c monitor.
from the journalctl -b -1 output, I can see:
Oct 31 11:47:34 jiayiwubuntu kernel: NVRM: _kgspProcessRpcEvent: Failed to process received event 0x1004 (RC_TRIGGERED) from GPU0: status=0x57
Oct 31 11:47:34 jiayiwubuntu kernel: NVRM: Xid (PCI:000f:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (GPU Reset Required)
and
Oct 31 13:01:33 jiayiwubuntu /usr/libexec/gdm-x-session[13129]: (WW) NVIDIA: Wait for channel idle timed out.
Oct 31 13:01:36 jiayiwubuntu kernel: NVRM: rpcRmApiAlloc_GSP: GspRmAlloc failed: hClient=0xc1d00056; hParent=0x01000001; hObject=0x01000013; hClass=0x0000ca6f; paramsSize=0x00000170; paramsStatus=0x00000062; status=0x00000062
Oct 31 13:01:36 jiayiwubuntu kernel: NVRM: nvAssertOkFailedNoLog: Assertion failed: Reset required [NV_ERR_RESET_REQUIRED] (0x00000062) returned from status @ kernel_channel.c:2871
Here comes the system information:
NVIDIA-SMI 580.178.04             Driver Version: 580.178.04     CUDA Version: 13.0
#25~24.04.1-Ubuntu SMP PREEMPT_DYNAMIC Thu Oct 22 21:37:03 UTC 2
it seems to be workarounded after revert back the kernel to 7.0.0-1019. I notice there is another thread tracking the similiar issue
DGX Spark repeatedly rebooting after most recent update
I will keep an eye on the update in the above thread.
Same issue here. I have two machines affected: my GX10 is stuck in a boot loop, restarting repeatedly, while my Founders Edition freezes shortly after booting and keeps heating up while it’s frozen.
Thanks @jiayiw for the logs and for confirming that going back to kernel 7.0.0-1019 works around it. The Xid 154 / NV_ERR_RESET_REQUIRED messages show the GPU entering a reset-required state, and the timing after the update points toward the newer kernel rather than the monitor itself. Until this is sorted out, staying on 7.0.0-1019 is a reasonable workaround.
To help us confirm, please share:
  • The exact failing kernel version: uname -r while booted into it (the version in your first post got cut off)
  • An nvidia-bug-report.sh log captured after a freeze, or journalctl -b -1 -k from the failing boot
  • Whether it also freezes on the newer kernel with the USB-C monitor disconnected, or over HDMI
@georgejtcaovii, the boot loop and freezes sound like the same regression. If you can reach the boot menu, try selecting the older 7.0.0-1019 kernel on both systems and let us know whether that stabilizes them. Please also post uname -r and a bug report or journalctl -b -1 -k from the GX10 and the Founders Edition.
Here somes the information requested. To answer your quesiton, it works fine if I run it headless with the newer kernel.
unameoutput.log (136 Bytes)
nvidia-bug-report.log.gz (166.8 KB)
