System Hanging Issue When Running VST UI and NVS UI Simultaneously on Jetson Orin Device
Hi everyone,
I’m encountering system hangs when trying to run both VST UI and NVS UI simultaneously on a Jetson Orin device with 32GB of RAM. Could the RAM capacity be causing this issue?
Any advice on troubleshooting or optimizing system performance in this scenario would be greatly appreciated.
Thanks,
Tanisha
Is it the same issue as this topic: Using the VST UI for viewing a live camera feed increases RAM usage until the system hangs ?
