system lag on memory transaction
Hi there,
I have a little problem with some code snippet.
When I run the following code:
[codebox]
//avoiding shmem bank conflicts + coalesced device mem reading (4 Byte)
*(unsigned int *)(shared_mem + shmem_thread_index + INDEX_ENV_DATA + (MULPLEX_BYTES_MEM * j)) = //BUG
*(unsigned int *)(device_mem + dvmem_thread_index +
(MULPLEX_BYTES_MEM * NUM_THREADS_PER_BLOCK * NUM_LOADABLE_ENV_PER_THREAD * i) +
(MULPLEX_BYTES_MEM * NUM_THREADS_PER_BLOCK * j) );	//device mem part -> shared mem part
[/codebox]
from the kernel function, the system (x11) get freezed for some seconds afterwards the terminal emulator get some
grafic errors.
Dont worry about the constants, as I think they do not matter in here.
The interesting thing is, that I can write integers into the shared memory area as well as I can read the integers
from the device memory. Only the combination of both seems to fail.
For example this: (atest is a 4 byte long char array…)
[codebox]
*(unsigned int *)atest = *(unsigned int *)(device_mem + dvmem_thread_index +
*(unsigned int *)atest = 2863311530; //0b10101010101010101010101010101010
*(unsigned int *)(shared_mem + shmem_thread_index + INDEX_ENV_DATA + (MULPLEX_BYTES_MEM * j)) = *(unsigned int *)atest;
[/codebox]
does work well, but if I cut the “*(unsigned int *)atest = 2863311530;” statement of the source, the problem will
be the same as before.
It seems like I write some data to reserved display memory but I think this will be in device memory…
For the case that I overwrite some important memory areas, where is the difference in overwriting it
with random data and a constant number? :wacko:
Thanks for your help and your ideas.
