On Jetson-TX2, the firmware that comes bundles along with L4T 28.1 is executing a SMC instruction, which is causing an exception and leading to generation of CPU trap, 0x17. This happens when the TX2 board is up and running.
However, SMC call for this Function Identifer (00000000c2ffff0f) is *NOT
* seen on Jetson TX1 board, with L4T 28.1
I would like to know, which Feature/driver on TX2 is resulting in this particular SMC call and would like to disable it, so as to prevent is from generating Trap 0x17.
On Jetson-TX2, the firmware that comes bundled along with L4T 28.1 is executing a SMC instruction, which is causing an exception and leading to generation of CPU trap, 0x17. This happens when the TX2 board is up and running.
However, SMC call for this Function Identifer (00000000c2ffff0f) is NOT seen on Jetson TX1 board, with L4T 28.1
I would like to know, which Feature/driver on TX2 is resulting in this particular SMC call and would like to disable it, so as to prevent it from generating Trap 0x17.
I am running a hypervisor on Jetpack 3.1. Now, if I start a web browser or launch a new terminal at the hdmi console, this SMC call gets invoked. Due to this call, the hypervisor crashes, so not able to get any logs.
Could you tell me, what feature to disable to avoid this SMC call being made in first place.
Hi Aleem,
Could you please tell us, which Hypervisor SW you are using and the steps to setup Hypervisor on L4T, so that we can try on our local-setup and debug it further ?
