DRIVE OS Version: observed on both 7.0.3 and 7.2.5
Error String: MCU reset 0x6 triggered
HW: observed on at least 3 boards, p3960-10-sw03
Issue Description: when switch power on or input “mcureset” on mcu console. there is 50%+ chance that during SOC initialization, MCU suddenly reset itself and report “MCU reset 0x6 triggered”.
Observation on SDK 7.0.3: after suddenly reset, MCU will ask for back side switch count down, and SOC will not be powered. MCU console still alive.
Observation on SDK 7.2.5: after suddenly reset, MCU will ask for back side switch count down, and a third suddenly reset with same reason, after that MCU console will hang and complete no response, SOC may or may not be powered. even when SOC is powered, mgbe1_0 does not work and Link statue is no.
Additional Info: during the power up sequence, no keyboard input was given. tried completely remove debug USB port, only power up by switch, still very high chance SOC will not be powered.
Console log:
703_mcureset_fail.txt (11.5 KB)
725_power_switch_on_fail.txt (25.1 KB)
703_power_switch_on_fail.txt (10.4 KB)
Test Steps:
simply turn on power switch, or input “mcureset” on MCU console.
7.2.5 MCU stuck observation:
mgbe1_0 link lost
It is not clear how to reproduce this issue. Could you share steps to reproduce the issue. Is it like you ran common_if_testApp -mcureset on target tegra console and notice these issues?
Hi @SivaRamaKrishnaNV
I added reproduce steps on the top, we are simply test powerup and hope that the system initialization successfully always. Right now the system requires multiple times of poweroff/reset to start up properly.
I ran mcureset on aurix console multiple times using DOS 7.2.5
I felt MCU console hanged for a while but after few seconds, it became active. On my remote test machine. I don’t have ethernet connected to mgbe1 interface. But I could see SoC booted with out any issue and accessible via minicom. I will check with mgbe1 connection behavior and update you.
NvShell>mcureset
Info: Executing cmd: mcureset, argc: 0, args:
NvShell>INFO: MCU_PLTFPWRMGR: Reseting
INFO: MCU_SYSSTATEMNGR: State update notification received- 3
INFO: MCU_PLTFPWRMGR: MPFDTI Timer is stopped
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring disable.
INFO: NVMCU_SOCPWRCTRL: Wait for Safe Shutdown notification (20s max)
Check for VRS10............................................................
INFO: NVMCU_SOCPWRCTRL: VRS10/11 BIST configuration done!
MCU_FOH: SPI E2E_P05Check Status : 7 : 0 [SOC0]
ERROR: MCU_ERRHANDLER: McuFoh : ReporterID - 0x810E ErrorCode - 0x3
I:RptrID - 0x810B PsCd - 0x8 - VMON Seq Record
I:RptrID - 0x810B PsCd - 0x7 - VMON Seq Match
I:RptrID - 0x810B PsCd - 0x23 - VMON Seq Ackld
INFO: PLTFPWRMGR_ETHCTRL: Ethernet peripherals de-initialized
INFO: MCU_PLTFPWRMGR: Request Eth deinitialization done !
INFO: MCU_LCMCLIENT: LCMServer connection is reconnecting or offline...
INFO: PLTFPWRMGR_ETHCTRL: Linkup status is not active
INFO: MCU_PLTFPWRMGR: Soc TMON disable.
INFO: MCU_PLTFPWRMGR: Board TMON disable.
INFO: PLTFPWRMGR_IOHWABS: Adding Delay of 5s for poweroff
INFO: PLTFPWRMGR_IOHWABS: Power down sequence is complete !
Status 0
*************** NvShell Initialization Start******************
DRIVE-V7.2.5-P3960-AFW-RH850-U2A16-3.05.03
Inforom detected Board ID - 63960-0010-D00
Compilation date: Jun 22 2026, 11:50:36
Enter 'help' to see the available commands.
*************** NvShell Initialized *************************
Press 'Enter' for NvShell prompt
NvShell>INFO: BtChn_Cfg: NvMCbk - TA DfltBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB DfltBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TA NxtBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB NxtBtChn Pri Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB DfltBtChn Red Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TB NxtBtChn Red Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TA DfltBtChn Red Blk, SId-12, JobRes-0
INFO: BtChn_Cfg: NvMCbk - TA NxtBtChn Red Blk, SId-12, JobRes-0
INFO: MCU Version PIM- DRIVE-V7.2.5-P3960-AFW-RH850-U2A16-3.05.03
INFO: PLTFPWRMGR_IOHWABS: Identified Board from Inforom - Board - 3960, BoardId - D00, Sku - 0010
INFO: PLTFPWRMGR_IOHWABS: NumSoc: 1
INFO: PLTFPWRMGR_IOHWABS: MCU reset 0x3 triggered...
INFO: SOMEIP: SD Bootchain service enabled on MCU
INFO: SOMEIP: SD SoCCtrl service enabled on MCU
INFO: SOMEIP: SD IST client service enabled on MCU
INFO: MCU_ERRHANDLER: SecOC: Sent initial test data to FSI [0]=0xde [1]=0xad [2]=0xbe [3]=0xef
INFO: MCU_PLTFPWRMGR: Number of SoCs to be powered: 1
INFO: MCU_BOARDVMON: Loading up common ADC Configuration for boards : TS2/TS3/TS4
INFO: FanMon_IoHwAbs: FAN Tach sensor measurement started
INFO: MCU_LCMCLIENT: MCU_LCMClient initialized successfully
I:RptrID - 0x810D PsCd - 0x16 - PwrCtrl Init Ok
INFO: NvMCU_SocTMON: Soc TMON initialized for 1 SoCs
I:RptrID - 0x810F PsCd - 0x7 - BootchainCfg Cfg Range Check Success
I:RptrID - 0x810F PsCd - 0x2 - BootchainCfg NvM Read Success
I:RptrID - 0x810F PsCd - 0x4 - BootchainCfg NvM Plaus Check Success
MCU_FOH: Switched to IDLE_STATE [SOC0]
MCU_FOH: Initialization done [SOC0]
INFO: SOMEIP: IST Client Service event Down Notification Received: 0x2
INFO: PLTFPWRMGR_IOHWABS: PMIC: Wakeup Status - 0x1, Error Status: 0x0
INFO: MCU_BOARDVMON: Voltage Monitor enabled for ADCJ0 and ADCJ1 signals
I:RptrID - 0x810A PsCd - 0xF - ISTManager:IST execution status read success.
I:RptrID - 0x810A PsCd - 0xE - ISTManager:No plausibility error in NVM data.
I:RptrID - 0x810A PsCd - 0x14 - ISTManager:No range plausibility error in NVM data.
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (494mV)
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (43mV)
INFO: MCU_PLTFPWRMGR: SW Latent Test configuration: 0x0
INFO: PLTFPWRMGR_IOHWABS: KL30_PROTECT Voltage (12122mV) exceeded threshold (6689mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: SAFE_3V3_PG Voltage (3241mV) exceeded threshold (3135mV). Continuing...!
I:RptrID - 0x810D PsCd - 0x8 - PwrCtrl Dio Chk Ok
I:RptrID - 0x810D PsCd - 0x7 - PwrCtrl Config Ok
I:RptrID - 0x810D PsCd - 0x17 - PwrCtrl PrePwrUp Ok
INFO: MCU_PLTFPWRMGR: MPFDTI Timer started with period set to - 28800 seconds
INFO: PLTFPWRMGR_IOHWABS: VBAT_SOC_FAULT is set to 1. Continuing...!
INFO: PLTFPWRMGR_IOHWABS: PWRYNK_SHDN is set to 1. Continuing...!
INFO: PLTFPWRMGR_IOHWABS: VDD_MV_CVM voltage (5008mV) exceeded threshold (4751mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: VDD_HV_CVM voltage (12141mV) exceeded threshold (6695mV). Continuing...!
I:RptrID - 0x810B PsCd - 0x20 - VMON Config Valid
I:RptrID - 0x810B PsCd - 0x13 - VMON i2c addr load passed
I:RptrID - 0x810B PsCd - 0xA - VMON Bist Passed
I:RptrID - 0x810D PsCd - 0x3 - PwrCtrl I2C Read Ok
I:RptrID - 0x810D PsCd - 0x6 - PwrCtrl I2C Read Crc Ok
I:RptrID - 0x810D PsCd - 0x14 - PwrCtrl VRS10 BIST Complete
I:RptrID - 0x810D PsCd - 0x19 - PwrCtrl VRS10 BIST Ok
I:RptrID - 0x810D PsCd - 0x9 - PwrCtrl Vrs10 Int Ok
I:RptrID - 0x810D PsCd - 0xD - PwrCtrl ActShdn Ok
I:RptrID - 0x810D PsCd - 0xF - PwrCtrl ActSlp Ok
I:RptrID - 0x810D PsCd - 0xE - PwrCtrl Actslp Ok
INFO: NvMCU_SocTMON: Soc-0 Temperature sensor initialized
I:RptrID - 0x810C PsCd - 0x17 - TMON Configuration in default mode pass
INFO: WAR: NVMCU_SOCPWRCTRL: Program correct OTPs for Power sequencing
INFO: SftyMon_IoHwAbs: toggle check of local and remote sensor successfull
I:RptrID - 0x810D PsCd - 0x2 - PwrCtrl I2C Write Ok
I:RptrID - 0x810D PsCd - 0x4 - PwrCtrl I2C Val Ok
I:RptrID - 0x810D PsCd - 0xC - PwrCtrl Actshdn Ok
Check for VRS11-1..........................................................
Check for VRS11-2...........................................................
I:RptrID - 0x810D PsCd - 0x1A - PwrCtrl VRS11 BIST Ok
I:RptrID - 0x810D PsCd - 0xA - PwrCtrl VRS11 Int Ok
INFO: NVMCU_SOCPWRCTRL: Programming thermal thresholds done!
I:RptrID - 0x810D PsCd - 0x10 - PwrCtrl Vrs10 NIRQ Chk Ok
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS10 !
I:RptrID - 0x810D PsCd - 0x11 - PwrCtrl Vrs11 NIRQ Chk Ok
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS11-1!
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ Toggle check Passed for VRS11-2!
INFO: NVMCU_SOCPWRCTRL: FUNC_NIRQ continuous monitoring Enabled!
INFO: SftyMon_IoHwAbs: Board Temperature sensor initialized
INFO: NvMCU_SocTMON: toggle check of local and remote sensor successfull
I:RptrID - 0x810C PsCd - 0xB - TMON Toggle Check for Alert & Shutdown Pass
I:RptrID - 0x810B PsCd - 0xD - VMON Plausibility pass
INFO: MCU_PLTFPWRMGR: Request NVMCU_SOCTMON_REQ_TOGGLE_CHK Service - finished
INFO: MCU_PLTFPWRMGR: Board TMON enabled.
INFO: NvMCU_SocTMON: Soc TMON init complete
INFO: MCU_PLTFPWRMGR: Soc TMON enabled ....
INFO: NvMCU_SocTMON: Thermal Monitoring Enabled
I:RptrID - 0x810C PsCd - 0x10 - TMON All thermal events are clear
I:RptrID - 0x810C PsCd - 0x11 - TMON All alert events are clear
INFO: NvMCU_SocTMON: Thermal Alert Trigger not present anymore
I:RptrID - 0x810C PsCd - 0xF - TMON No notification present
INFO: MCU_PLTFPWRMGR: Bootchain selection mode: GPIO
INFO: BtChn_Cfg: Tegra x1 Boot Chain is : A
INFO: BtChn_Cfg: Btchn Pin SOC0_BOOTCHAIN0 set to 0
INFO: BtChn_Cfg: Btchn Pin SOC0_BOOTCHAIN1 set to 0
I:RptrID - 0x810F PsCd - 0x6 - BootchainCfg Dio set success
INFO: NVMCU_SOCPWRCTRL: Tegra reset released
MCU_FOH: Start Monitoring Called [SOC0]
INFO: MCU_PLTFPWRMGR: Start Network power-up sequence .
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_3V3_AO voltage (3313mV) exceeded threshold (3135mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V8 voltage (813mV) exceeded threshold (759mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_3V3 voltage (3336mV) exceeded threshold (3135mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_1V2 voltage (1214mV) exceeded threshold (1140mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V9 voltage (901mV) exceeded threshold (854mV). Continuing...!
INFO: PLTFPWRMGR_IOHWABS: ETH_SYS_0V84 voltage (841mV) exceeded threshold (798mV). Continuing...!
INFO: MCU_PLTFPWRMGR: Request Power-up Ethernet Switch done !
INFO: PLTFPWRMGR_ETHCTRL: Ethernet Link Active
INFO: Network config 0x3: Hyperion 8_1
INFO: RTK_SWITCH: Realtek switch firmware init complete at SMI:24
INFO: RTK_SWITCH: Chip revision scan: Skipping V1 : 0
INFO: RTK_SWITCH: Detected chip revision CHIP_907XD_VA
ERROR: RTK_SWITCH: Condor1: Failed to configure switch
INFO: RTK_SWITCH: Deny all: Enabling port forwarding. SMI:24
INFO: RTK_SWITCH: Condor1 Switch init complete
INFO: RTK_SWITCH: Realtek switch firmware init complete at SMI:25
ERROR: RTK_SWITCH: Condor2: Failed to configure switch
INFO: RTK_SWITCH: Deny all: Enabling port forwarding. SMI:25
INFO: RTK_SWITCH: Condor2 Switch init complete
INFO: MRVL_SWITCH: FIR ACTIVE pin disabled (DENY ALL)
INFO: MRVL_SWITCH: Fir switch 88Q5152 init complete
Initialize 88Q222X PHY with SMI address: 3 in Master Mode, Detected Q2221M Package!!!
INFO: PLTFPWRMGR_ETHCTRL: Ethernet switch and Phy initialization completed..
INFO: MCU_PLTFPWRMGR: Request Eth initialization done !
INFO: MCU_PLTFPWRMGR: VRS11 PG Monitoring enable.
INFO: MCU_PLTFPWRMGR: Power-up sequence is complete !
INFO: CmnIf: Wdg Enabled Success!
Power on the system
INFO: MCU_ERRHANDLER: Published Power State: Power-up complete
Init Max load - 100, Average Load - 100
INFO: MCU_SYSSTATEMNGR: State update notification received- 2
INFO : MCU_ISTMGR: IST_DONE pin no monitor time of 2000 ms over.
I:RptrID - 0x810A PsCd - 0xD - ISTManager:IST DONE pin stuck at low not observed.
INFO: SftyMon_IoHwAbs: PG_VRS11 monitoring started...
MCU_FOH: Switched to FSI_MONITORING_STATE [SOC0]
MCU_FOH: SOC error pin is asserted [SOC0]
ERROR: MCU_ERRHANDLER: SOC error pin is asserted
MCU_FOH: Sending SecOC Data: [0] 0xde [1] 0xad [250] 0xfa [251] 0xfb [SOC0]
MCU_FOH: Spi Transmit Started [SOC0]
MCU_FOH: ErrReport: ErrorCode-0x5801 ReporterId-0xe04c Error_Attribute-0x4000080e timestamp-0x3de2f69 [SOC0]
MCU_FOH: ErrReport: ErrorCode-0x2807 ReporterId-0xe04c Error_Attribute-0x40000806 timestamp-0x3e3d95a [SOC0]
MCU_FOH: Periodic Status [0] 0xab [1] 0xcd [250] 0x12 [251] 0x34 [SOC0]
NvShell>INFO: MCU_LCMCLIENT: LCMServer connection is online !
INFO: SOMEIP: IST Client Service event Available Notification Received: 0x2
INFO: MCU_LCMCLIENT: Packet type received: 0x01, No action required
INFO : MCU_IST_COM: IST Client Ready Event Received
INFO : MCU_IST_COM: Using SOME/IP for IST GetResult command
INFO : MCU_IST_COM: SOME/IP GetResult command sent successfully
INFO : MCU_ISTMGR: IST Manager initialized to send/receive commands
INFO : MCU_IST_COM: SOME/IP response received for GetResult command
I:RptrID - 0x810A PsCd - 0x11 - ISTManager:IST result fetched.
INFO : IST_TESTAPP: IST Result Ready to fetch
NvShell>
NvShell>
NvShell>
NvShell>
NvShell>
NvShell>
Dear @snow.yin ,
Could you please share the network connection pictures(like which port, dongle used and what are interfaces are up in that setting)?
Thanks a lot for your feedback.
here is out network setup:
and one more thing is, when the issue is reproduced, MCU console is printing very slowly with 1 dot per second “Check for VRS10…”, and the fan is not spinning.
The “cold boot with power switch on” can reproduce the issue much more easiser than “mcureset”.
It means when board is running, turn off/turn on the switch on board(where power chord is connected) reproduce the issue?
Only mgbe1 interface is disabled and rest all working?
yes, exactly.
yes, only MGBE1_0’s link is off, others works fine.
Here is more detail, we tested various combination, remove or connect each HW on our bench.
- when MBGE3_0 is connected to a gPTP master through technica adaptor, issue (MCU reset 0x6, MCU stuck and SOC MBGE1_0 link off) can be reproduced more easily.
- when MBGE3_0 is connected to technica adaptor, but disconnect adaptor and gPTP master, issue is gone.
- when MBGE3_0 is connected to gPTP master through Nvidia adaptor, issue can be partially reproduce (MCU reset 0x6 still happen, but second or third MCU reset will work, MCU won’t stuck, SOC MBGE1_0 link on)
- when MCU reset 0x6 happen, it ask “Do you want to switch MCU FW to Back Side? (y/n) (timeout 10s)”, my colleague switched to back side, and MCU stay in back side, based on his test, back side is much more stable.
If only mgbe1 is connected, you don’t see any issue?
yes, by far no abnormal observed.
we would try a case 10+ times powerup/reset, if no “MCU reset 0x6” then it is considered as OK.
We tried on a SKU 12 with 7.0.3
same observation: so long as MGBE3_0 and gPTP master disconnected, issue will be gone.
