Flashed my TX2 with the latest JetPack 3.3 — L4T R28.2.1 release. Recently, a “System program problem detected” always pops up at boot. I only installed some minor packages like Firefox. The entire board is relatively clean.
I experienced a simiar problem with previous version of JetPack, which turned out to be SD Card related. But this time my SD Card seems working fine.
If I click “Report problem” in the error prompt window, it goes to a Ubuntu popup “Sorry, Ubuntu 16.04 has experience an internal error”. Further click on “Show Details”, the ExecutablePath was
/usr/lib/colord/colord-sane
ProblenType: Crash
It’s very similar to what I have seen in the past, which means the error message isn’t much helpful to root cause the issue.
I then ran “dmesg” on a terminal, and searched for “error”. Got following:
[ 4.871507] xhci-tegra 3530000.xhci: UTMI port 0 has OTG_CAP
[ 4.871508] xhci-tegra 3530000.xhci: No USB3 port has OTG_CAP
[ 4.894680] xhci-tegra 3530000.xhci: Direct firmware load for tegra18x_xusb_firmware failed with error -2
[ 4.894682] xhci-tegra 3530000.xhci: Falling back to user helper
Please let me know if any other commands I should try in order to debug.
