I often get an error information that System program problem detected. However, the system seems to work normally. I just confused about why it appears.
Since a few days I get the same message, see screenshot. Maybe the reason is the r-pi V2 camera. It is no problem at the moment, but if the multicopter is in the air it would destroy the videofeed.
Is it possible to deactivate the message?
Best regards,
Wilhelm
It has nothing related to device nor driver. it is ubuntu issue.
checking these links for possible solutions:
Hi sunxishan,
thank you very much.
Best regards,
Wilhelm
Any time any program crashes this will show up. If you start the “report” part it’ll tell you what program had the issue. Whether or not it is related to the Nano itself nobody can say without knowing what program it is.
