By default the Application has a resolution of 1280 * 720 with 30 fps,
I have changed the CSI Camera mode 1920 * 1080 resolution of 30 fps. Once I Executed the Application. detectnet (object-detection) is proper and power modes are in MAXN mode.
Once the Application Started Running, I am Facing the “System throttle issue due to Over-current” Issue
With some GPU-intensive jobs, the XavierNX might reach the overcurrent limit.
The maximum OC value on the XavierNX devkit is 5A. So you will see the warning message.
