hi ,你好。
when i use jetson nano 4GB to run a software, display somethings.
我这边想知道,提示电流过载的时候,一般会因为哪些问题而产生。
hi ,你好。
Our software will throttle the processor and drop the performance.
what meanings?? that meangings temperature is high ,and the software 将会降低性能。
the right temperature for the environment with the jetson nano 4G using is??
from ?? ℃ to ?? ℃,thanks very much.
Temperature and current are two different things.
https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/power_management_nano.html# → " Under Voltage and Over Current Protection"
我昨天看过你们的文档了,这边电流过低或者过高都会提示这个system-throttled-due-to-over-current提示,然后我们这边想知道的是,温度这边对jetson nano4G的板子有哪些影响??会降低板子的性能??是否也会触发开发板的保护机制??导致外接摄像头这边出现重影??
The document I just shared also tells what will happen when temperature goes high.
会降低板子的性能
Yes
是否也会触发开发板的保护机制
Yes
导致外接摄像头这边出现重影
We are not sure.
thanks,i got.
我刚刚问错了,摄像头这块属于外设,这边板子的性能降低会出现HDMI输出信号不稳定或者干扰的现象么??
我这边找的温度表格:
No… the document already told you it is C but not F…
难道那个温度表是极限值??小于那个温度表开发板都可以正常运行么??开发板的合理运行温度范围是多少呢??
The board will work fine below those temperature.
the borad is so great!!!niubility!! so, what happen the HDMI signals appears unstable ??有哪些可能会导致HDMI的信号不稳定,以及出现borad 死机。
We don’t have answer for that. When do you see that behavior?
