Has anyone else had issues with the new control panel? Currently I can’t get the system update to work in the control panel. It just hangs.
Specs:
Windows XP SP3
XFX 790i Ultra
EVGA 260 GTX
All the newest drivers and software updates
Specs:
Windows XP SP3
XFX 790i Ultra
EVGA 260 GTX
me too worked fine first week then nothing just hangs
specs;
vista 32bit
msi K9N2 SLI PLATINUM
dual 8800gts 512
anyone have a solution???
I have the same problem. The last update I made was on 11/20/08. So far I can’t find a reason why everything in the NVIDIA Control Panel works except the "Update Your System Drivers’ option. it just hangs and then eventually goes to 'Not Responding. :wacko:
I have a dual boot system with Vista & XP 32 bit on seperate hard drives and it isn’t working on either.
Anyone have any ideas?
same exact issue, and adding that i made the mistake to put that i want to check periodically for drivers updates… PUM i cannot even enter to the option anymore…
I have the same problem!!!
I keep uninstalling this latest driver. If i go back to old drivers my sli works great via gpu-z. Both cards get a load. Every time i download the latest software my control panel freezes and my sli does not work. Fix it Nvidia!!!
8 core amd
8 gigs ram
geforce 580s x2 sli
asus crosshair mobo
