Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
To check the services, I tried to execute systemd-analyze command, but it shows the message; ‘Bootup is not yet finished. Please try again later’.
I executed systemctl list-jobs and found there are two waiting services.
$ systemctl list-jobs
JOB UNIT TYPE STATE
420 dev-loop0.device nop waiting
421 sys-devices-virtual-block-loop0.device nop waiting
However, I cannot stop those services and systemd-analyze still doesn’t work.
Of course, I tried reboot the system for several times, nothing improved.
No, user services are implemented on the system.
Unfortunately I cannot get the complete output of systemd-analyze as it does not work.
Also, the journal log was broken (journalctl --list-boot returns only one boot started at yester year).
Actually, just after I wrote the post, systemd-analyze worked correctly, but after about 10 times of reboot, AGX returned into the original status.
BTW, can I disable dev-loop0.device and sys-devices-virtual-block-loop0.device if they do not affect the system?
The issue isn’t seen on my clean DRIVE OS 5.2.0 system and your systemd-analyze output shows “Startup finished” so I presume you already solved the problems on your side. Thanks.
