我在aarch64的平台上使用Nvidia T1000,想在uefi启动时能够实现bds阶段显示logo,但发现没有显示,排查发现卡中optionrom读出的驱动为x86架构的,请问有没有能够支持aarch64的gop驱动?
Hello @foorwaw,
When searchign on the NVIDIA driver Download pages, you need to chose the combination as visible in the screenshot:
That will show the correct driver as a result, in this case Driver Details | NVIDIA
Thanks for your reply. I downloaded this driver, after decompression does not seem to find the UEFI drivers, only for the Linux system to use the driver, Is there a way I can get to the UEFI display driver of this card ?
If I understand you correctly, than you have trouble with UEFI secure boot?
First thing to try would be to disable it and see if the installation goes through then.
If not, then during the installation process the driver installer should ask you if you want to authenticate the driver and install a signed key through the MOK utility. If you follow the instructions there to the letter, you should be able to install the driver also in a UEFI secure boot system.
Security boot was not used here, and I check out other vendors like AMD, they support the uefi gop driver, here is the url : AmdGopx64.efi , Can NVIDIA also provide a separate UEFI GOP driver for T1000?
As I mentioned, there are only the drivers you will find on our driver download pages.
Other Aarch users are using those without any issues. Maybe you could check our specific Linux subcategory here on the forums to find more help.
okay :( . It’s hard to find Aarch64 UEFI GOP related topics in the forum, but thanks for your patience answer :D
