T10P bandwidth problem
My T10P board is not showing the expected bandwidth:
Quick Mode
Host to Device Bandwidth for Pageable memory
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 1415.2
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 1242.7
Quick Mode
Device to Device Bandwidth
33554432 84321.5
My driver is the latest one (Linux driver 177.67) and also BIOS is the most recent one for my motherboard (GeForce7100/nForce630i Chipset).
I read in another posting that I’d better check PCI-express “activated” but my BIOS doesn’t have such a menu. Anyway, I can see using nvidia-settings GT200 configuration contains “PCI-express 16x”.
As for power cable connection, I connected two 6-pin connectors.
What could be the reasons for having low bandwidth?
Thanks,
-youngmin
Try using pinned memory. If things improves a lot, then CPU <-> DRAM bandwidth might be the culprit for low pageable memory bandwidth.
If things don’t improve, then maybe a deficient BIOS, or a PCIe x16 connector that only has 8 lanes connected.
HTH
