Hi, Shane
I can still reproduce the issue with the commands:
gst-launch-1.0 -e -v \
nvarguscamerasrc sensor-id=0 sensor-mode=0 num-buffers=5184000 ! \
'video/x-raw(memory:NVMM),width=3864,height=2180,framerate=60/1,format=NV12' ! \
nvvidconv flip-method=1 ! \
fpsdisplaysink video-sink="fakesink sync=false qos=false" \
sync=false text-overlay=false
nvarguscamerasrc sensor-id=3 sensor-mode=0 num-buffers=5184000 ! \
Below are the logs:
Nvargus daemon log:
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module3
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: NvPclHwGetModuleList: WARNING: Could not map module to ISP config string
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: NvPclHwGetModuleList: No module data found
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree: /proc/device-tree/tegra-virtual-camera-platform/modules/module0/drivernode1
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: OFParserGetVirtualDevice: virtual device driver node not found in proc device-tree: /proc/device-tree/tegra-virtual-camera-platform/modules/module1/drivernode0
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: ---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: CAM: serial no file already exists, skips storing again---- imager: Found override file [/var/nvidia/nvcam/settings/camera_overrides.isp]. ----
Aug 25 06:50:24 caper-desktop nvargus-daemon[839]: E/ libnvphs:socket: Error[2]: socket connection /var/lib/nvphs/nvphsd.ctl to PHS failed: No such file or directory
Aug 25 06:50:24 caper-desktop nvargus-daemon[839]: D/ libnvphs:socket: Warning: connecting to Power Hinting Service failed. Is PHS running?
Aug 25 06:50:24 caper-desktop nvargus-daemon[839]: CAM: serial no file already exists, skips storing again=== gst-launch-1.0[42827]: CameraProvider initialized (0xffff9467b5d0)SCF: Error BadValue: NvPHSSendThrou
ghputHints (in src/common/CameraPowerHint.cpp, function sendCameraPowerHint(), line 56)
Aug 25 06:50:24 caper-desktop nvargus-daemon[839]: E/ libnvphs: Error: NvPHSSendThroughputHints[usecase=camera, hint=MinCPU, value=4294967295, timeout_ms=1000]: queue_or_send() failed
Aug 25 06:51:54 caper-desktop nvargus-daemon[839]: CAM: serial no file already exists, skips storing again=== gst-launch-1.0[45932]: Connection established (FFFF55FEE900)=== gst-launch-1.0[45932]: CameraProvider
initialized (0xfffefc000c20)CAM: serial no file already exists, skips storing againPowerServiceCore:handleRequests: timePassed = 541
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: Module_id 30 Severity 2 : (fusa) Error: ResourceAlreadyInUse All captures are already pending, no idle captures available in:/ca
pture/src/fusaViHandler.cpp 628
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: Module_id 30 Severity 2 : (fusa) Error: ResourceAlreadyInUse propagating from:/capture/src/fusaViHandler.cpp 470
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/FusaCaptureViCsiHw.cpp, function startCaptureInternal(), line 879)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function doCSItoMemCapture(), line 536)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureRecord.cpp, function issueCapture(), line 483)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1530)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: (propagating from src/services/capture/CaptureServiceDevice.cpp, function issueCaptures(), line 1359)
Gstremaer log:
Aug 25 06:35:20 caper-desktop systemd[1]: Started Argus daemon.
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: === NVIDIA Libargus Camera Service (0.99.33)=== Listening for connections...=== gst-launch-1.0[42827]: Connection established (FFFF99BE8900)OFParserListModules:
module list: /proc/device-tree/tegra-camera-platform/modules/module0
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module1
Aug 25 06:50:23 caper-desktop nvargus-daemon[839]: OFParserListModules: module list: /proc/device-tree/tegra-camera-platform/modules/module2
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: (propagating from src/common/Utils.cpp, function workerThread(), line 115)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error ResourceAlreadyInUse: Worker thread CaptureScheduler frameStart failed (in src/common/Utils.cpp, function workerThread(), line 134)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: (propagating from src/api/Buffer.cpp, function waitForUnlock(), line 644)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: (propagating from src/components/CaptureContainerImpl.cpp, function returnBuffer(), line 426)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 1004)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 411)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: (propagating from src/components/stages/MemoryToISPCaptureStage.cpp, function doHandleRequest(), line 144)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: Sending critical error event for Session 2
Aug 25 06:57:50 caper-desktop nvargus-daemon[839]: (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Aug 25 06:57:51 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: Sending critical error event for Session 0
Aug 25 06:57:51 caper-desktop nvargus-daemon[839]: (in src/api/Session.cpp, function sendErrorEvent(), line 1039)
Aug 25 06:57:51 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: Capture Scheduler not running (in src/services/capture/CaptureServiceDevice.cpp, function addNewItemToSchedule(), line 1004)
Aug 25 06:57:51 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: (propagating from src/services/capture/CaptureService.cpp, function addRequest(), line 411)
Aug 25 06:57:51 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: (propagating from src/components/stages/SensorCaptureStage.cpp, function doHandleRequest(), line 87)
Aug 25 06:57:51 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 158)
Aug 25 06:57:52 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: (propagating from src/components/amr/Snapshot.cpp, function waitForNewerSample(), line 91)
Aug 25 06:57:52 caper-desktop nvargus-daemon[839]: SCF_AutocontrolACSync failed to wait for an earlier frame to complete.
Aug 25 06:57:52 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: (propagating from src/components/ac_stages/ACSynchronizeStage.cpp, function doHandleRequest(), line 126)
Aug 25 06:57:52 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: (propagating from src/components/stages/OrderedStage.cpp, function doExecute(), line 137)
Aug 25 06:57:59 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: (propagating from src/services/capture/CaptureServiceEvent.cpp, function wait(), line 59)
Aug 25 06:57:59 caper-desktop nvargus-daemon[839]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc for sensor guid 0 count -1661607168
Aug 25 06:57:59 caper-desktop nvargus-daemon[839]: Error: Camera HwEvents wait, this may indicate a hardware timeout occured,abort current/incoming cc for sensor guid 2 count -1661607168
Aug 25 06:58:06 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: 5 buffers still pending during EGLStreamProducer destruction (in src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 30
1)
Aug 25 06:58:06 caper-desktop nvargus-daemon[839]: SCF: Error InvalidState: 3 buffers still pending during EGLStreamProducer destruction (in src/services/gl/EGLStreamProducer.cpp, function freeBuffers(), line 30
1)
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26805
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26804
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26803
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26801
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26800
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26797
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26798
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 26799
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: SCF: Error Timeout: waitForIdle() timed out (in src/api/Session.cpp, function waitForIdleLocked(), line 969)
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 21466
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 21465
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 21464
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 21463
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 21461
Aug 25 06:58:11 caper-desktop nvargus-daemon[839]: waitForIdleLocked remaining request 21462
