T5000 carrier board CSI trace impedance is dif 95 or dif 85
hi,i have the T5000 carrier board, the P4071_A02_Allegro brd CSI mipi trace routing is line width 0.105mm, and gap is 0.13mm, it is diff pair 85Ω, but the deisgn guide file is diff 90–100Ω( diff 95Ω ) , which one is correct, which one should be for design reference? thanks for your help.
The nominal trace impedance target when designing should be the differential 90–100Ω stated in the Design Guide. If that is not possible, up to 10% tolerance from 90-100Ωcould be used, which fits the 85Ω on the P4071 carrier board reference.
